ABS in snow
Old Dec 16, 2007 | 06:47 PM
Mr McCabe's Avatar
ABS in snow
Tonight for some reason my ABS light came on and I lost my ABS function. Right now we are getting a big snow storm and there is a lot of snow already on the ground. I only lost my ABS for about 5 minutes. Anyone know why this happened?
Old Dec 17, 2007 | 05:01 AM
Mr McCabe's Avatar
Anyone???
Old Dec 17, 2007 | 11:51 PM
Kwin's Avatar
im not really sure but maybe the car thought you were better off with out it...maybe....i really dont know
Old Dec 17, 2007 | 11:54 PM
Frankruffolo257's Avatar
snow packed in the back of the brake rotor may have caused a loss of signal from the tone ring to the wheel speed sensor. Just a wild guess.
Old Dec 17, 2007 | 11:56 PM
HackAbuse's Avatar
The car is better without ABS anyway
Old Dec 17, 2007 | 11:57 PM
68nova200's Avatar
just man it up and drive without it. heck my car doesnt even have ABS i am still alive after driving in two storms in the past week.
Old Dec 18, 2007 | 12:03 AM
killah_thug08's Avatar
i hate abs lol, first time i took my dads car out when i was 15 without him knowing i jammed the brakes and thought i broke something and parked beside the road till my dad came LOL
Old Dec 18, 2007 | 12:06 AM
1_quick_balt's Avatar
i hate abs!!!.... you can atleast control how so stop with out it... all abs does is make a funny noise and you have no control.... i learned and still drive a car with out abs...
Old Dec 18, 2007 | 12:18 AM
Mr McCabe's Avatar
Abs is great for wet road conditions but it REALLY blows in the winter!! I'd perfer to have no Abs but I don't want to be staring at the Abs light all the time either.
Old Dec 18, 2007 | 12:20 AM
true.... that light would really annoy me too.....
what is this ABS light and traction control thing people are speaking about on there display under the odometer? when my abs kicks in i see no light come on and i have never see my display say traction control or w.e
Old Dec 18, 2007 | 12:29 AM
an0malous's Avatar
ABS should be a toggled safety item IMO.
if you look around, there were some studies done a few years ago, that showed ABS systems on high traction roadways, decreased braking distance considerably. GREAT!!!
but they also showed that on loose driving conditions, like gravel, or snow,
your braking distance can actually be INCREASED up to like 20%
pretty messed up considering you cant turn it off.
Old Dec 18, 2007 | 12:45 AM
HackAbuse's Avatar
I've had both my t/c and abs disabled for over a year.
The car is SO much better without it
Old Dec 18, 2007 | 01:53 AM
an0malous's Avatar
i wouldnt disable it in the summer if i were you....
on pavement its been shown countless times, that a professional race driver without ABS cant stop a car sooner than a soccer mom who has it.
it really is a great system. just not so great on snow and gravel
also, tampering with a safety device can get you in some big trouble...
Old Dec 18, 2007 | 10:15 AM
mlafran's Avatar
I had the same thing happen right in the middle of that storm. Lost ABS, Service Traction warning, etc. Seemed like half the dash lights were on. My guess it was snow packed around a sensor. The wheel area was pretty clogged up and after driving a bit it cleared and I haven't seen the warning since. So I guess I'm not going to worry too much.
Old Dec 18, 2007 | 10:39 AM
MTPockets's Avatar
That's your most likely cause of something intermittent. A piece of snow/ice/dirt got lodged over the face of a wheel speed sensor and eventually got knocked off. Having driven in Buffalo winters all my life, I'd have to say this is where ABS really shines. You either have to manually pump the crap out of your brakes and white knuckle the hell out of it in a panic situation, or you will totally loose it and wreck. I'd rather just mash and steer on an ABS equipped vehicle. ABS It's nice on the ice & snow. Horrible elsewhere IMO. FWIW, my cheap azz Cobalt has no ABS.
Old Dec 18, 2007 | 10:42 AM
roadrage06's Avatar
mine is in the shop right now for this. it just randomly came on while i was driving the other night and was on and off periodically, then stayed off for the past week. i'll let you know the results, they are expecting it done today.
Old Dec 18, 2007 | 10:52 AM
hawlyns711's Avatar
if you have good tires, keep your abs. but if you're like me and have bad tires, i pulled the abs fuse and i can stop considerably shorter in snow
Old Dec 18, 2007 | 10:53 AM
MTPockets's Avatar
A higher dollar code scanner will tell you exactly which wheel speed sensor the ABS system is getting funky readings from. No idea in on the Cobalt OBDII Controller Area Network (CAN) system, but on some regular OBDII GMs, all you had to do is jump pins 4 & 12 on the OBDII plug (Data Link Connector) and count the flashes of the ABS light to decode. Dealers love ABS jobs. Very easy money makers for them.
Old Dec 18, 2007 | 03:55 PM
so anyone can disable abs around winter season if they do not want it by just pulling a lil fuse? is the fuse under the hood or? explain more please
Old Dec 18, 2007 | 11:08 PM
hawlyns711's Avatar
well i have a redline if that makes a difference, but there were 3 abs fuses under the hood in the fuse box, i pulled the biggest one (40 amp) and that did the trick
Old Dec 18, 2007 | 11:43 PM
and thats not gunna **** around with the electrical system or pcm or w.e?
Old Dec 19, 2007 | 09:03 AM
hawlyns711's Avatar
i've been doing it for about 3 weeks now, no problems. only the abs light in the cluster is on, but you just gotta live with that. i' not telling you it's safe (for the risk of getting banned) but it works great
Old Dec 19, 2007 | 10:06 AM
roadrage06's Avatar
Ok, got my car back yesterday about the ABS light, and they could not find a reason or cause for it. All my sensors are fine. I told them about the information on this thread and they confirmed that snow build up near the wheel speed sensor is indeed the most likely cause of this during snowy conditions. There is probably nothing wrong with you brake system, it's just a result of the weather. Hope this helps.
Old Dec 19, 2007 | 07:21 PM
MTPockets's Avatar
Yep, you'll see this happen more often on vehicles that don't have much distance between the axle and the road. Less common on trucks, suvs, etc.
