Ahhhh! Spark plug ceramic fell into block!
Old Dec 28, 2012 | 06:28 PM
NICOMAN's Avatar
Idk how the hell the ceramic at the top of my spark plug cracked .. But it did and fell throughthe hole on top of a piston.. I could see the pieces soo i got most of it out with some tape on a wire .. I had a grip of one of the bigger pieces with a claw but it fell of and now i cant see it .. Wtf r my options aside from taking the whole head off?! Pplease and thank u .
Old Dec 28, 2012 | 06:34 PM
gotboost?17's Avatar
Nothin Stock
maybe a magnet? or blow some air in there till u c it
Dave104's Avatar
vacuum? Just a thought.
Old Dec 28, 2012 | 06:35 PM
Sox-Fan's Avatar
Got Brakes?
tiny mirror and a light so you can see what's left in there and possibly fish it out.
Old Dec 28, 2012 | 06:39 PM
royce777's Avatar
yeah try to vaccum it out
Old Dec 28, 2012 | 06:44 PM
NICOMAN's Avatar
Yeah gunna try the vacuum route .. What if i started it without that spark plug in? Think it would just crush up the pieces and let it exit through the exhaust valve? Its ceramic and sould pretty much vaporize no? My biggest worry is even if it does exit thru the exhaust valve.. Could damage my turbo .. Idk i hope vacuum works
Old Dec 28, 2012 | 06:49 PM
Nothin Stock
i think ceramic is hard
Old Dec 28, 2012 | 09:18 PM
NICOMAN's Avatar
Soo i shop vacced out what i could then cracnked the hell out of it with that spark plug out .. Got it all plugged back in n it run rouph for a little def heard something bouncing arounf.. Then heard it in the turbo and finally it shot out im assuming cuz its running better then b4 now lol
Old Dec 28, 2012 | 10:59 PM
Magz_rule's Avatar
-_-
Old Dec 28, 2012 | 11:01 PM
C_A_D88's Avatar
Really....
Old Dec 29, 2012 | 12:16 AM
xxenjoi11's Avatar
this..
hasnt anyone seen the video of ceramic shattering windows effortlessly?
to OP id use an air hose or shop vac. i would NOT start it like that..
Old Dec 29, 2012 | 12:45 AM
Sox-Fan's Avatar
Got Brakes?
sounds like too late now. bet those impellers just loved that hunk of ceramic hitting them.
Old Dec 29, 2012 | 12:49 AM
Beck's Avatar
ouchie, i would have tried a little harder to vacuum that out. All those ceramic chunks can potentially damage pretty much everything from the piston/valves back
Old Dec 29, 2012 | 01:36 AM
Nothin Stock
this..
Lol today i dropped a peice of carbide to a 1/4 inch bottle an just destroyed it, i figure ceramic is just as hard
Old Dec 29, 2012 | 02:47 AM
NICOMAN's Avatar
well i did get most of it out sat there for like an hour using everything i had(shop vac..claw ..and some wire with duct tape lol )..then when i started it with 3 plugs in and that one cylinder open seemed to push some more out..and ceramic crumbles pretty easily ..hence it broke without any real force..plus..after a while of trying to get it out ..**** if im going to take the whole head off its gunna be cause i have to lol .. soo it was worth a shot..and no joke..car is pulling harder then it ever has !
Old Dec 29, 2012 | 03:07 AM
Mine ate one once. About 15k ago. Still runs fine, but mine didn't have a turbo to go through still. If it runs fine now just go with it.
Old Dec 29, 2012 | 08:57 AM
Aleksey's Avatar
This is where I'd use the suction unit off the ambulance at work with a catheter to suck all that stuff out lol
Old Dec 30, 2012 | 09:00 PM
prevsrt4owner's Avatar
The piston will crush it, and it will be sent through the exhaust side, lol. Probably will score the $hit out of the cylinder. Anyway, you better hope by turning over the engine (with the plugs out) there was enough force to blow the particles out of the cylinder. Been there! Done that! I could tell you the story, but it's pretty embarrassing.
Old Dec 31, 2012 | 08:21 AM
LethalSS's Avatar
see now you gained like 5 hp...
m0ar power YO!!!
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
