Air Blowing on and off in Cabin, won't stop..HELP!!
O.k this problem just started last night, after I drive for a while the air comes on full blast inside my car,(it's like you turning up to 4) and when i try to turn it down to 1 or 0 on the dail, it won't do nothing. After a while the air will go back to the setting I had it at and I can control it with the dail. The heating and cooling dail works and i can turn it from cold to hot. It's just this problem keeps happening.
My question is what is the problem, and does my warrenty cover it? When I go into the dealership soon?
Ya But Will the Dealership charge me to look at the probelm?
If when you have this problem the motor is going to high and you cant turn it off there are only two possibilities.
A: the orange wire for the blower motor is shorted to ground somewhere.
B: The control unit(knobs) is bad. Normally i would say you would feel something wrong with the speed knob, but its not necessarily going to feel broken
OrangeCoba
09-25-2015 06:06 PM
