Alittle Help...
Alittle Help...
i'm throwing a cel for p0341...cam sensor... it came and then went away...and now back...but the car is running fine and idleing fine...no other problems is this bad to run of for a few days...i dont run my car hard....
also where is the location of the cam sensor??
the cam sensor is located on the driver's side at the rear of the engine...it's butted up against the engine pretty much....look for a cylindrical aluminum housing above the thermostat housing...that's the camshaft position sensor housing....it's bolted to the back of that
it's kinda common for them to go out
