B0085...? Where is the side impact sensor located?
Old Aug 4, 2009 | 11:29 PM
grahamSS33's Avatar
I have a 2006 SS/SC and I put it on a diagnostic computer and it came up with this code:
B0085 LF Side Impact Sensor
The car was hit on the driver side rear, only the side bag deployed. My airbag light is on, so I need to replace the sensor, but I am not sure if it is the sensor that is in the door, or under the hood. Can anyone help me out? I searched threads, but only found my older posts asking the same question. also, if you know, will this sensor take care of the problem?
GM part number: 15212949
I know that this one is the sensor for the door. No idea where it is though or how to find and change it.
Old Aug 5, 2009 | 12:14 AM
Fast Black SS's Avatar
Ur code read ***** lol
Old Aug 5, 2009 | 01:19 AM
grahamSS33's Avatar
haha...man I was excited to see a response...not so much now...haha good observation though
Old Aug 8, 2009 | 05:41 PM
grahamSS33's Avatar
anybody? I really need help
Old Aug 8, 2009 | 07:25 PM
Coblasts's Avatar
Heres every thing,you will have to decide.
Hope this helps.
Inflatable Restraint Front End Sensor
In top center of the radiator support near the hood latch
Inflatable Restraint Front Passenger Presence System (PPS) Module
Under the passenger seat
Inflatable Restraint Front Passenger Presence System (PPS) Sensor
Under the upholstery in the passenger seat cushion
Inflatable Restraint Passenger Seat Belt Tension Sensor
In the passengers seat belt buckle
Inflatable Restraint Instrument Panel (I/P) Module
On the right side of the I/P, above the glove compartment
Inflatable Restraint Passenger Air Bag On/Off Indicator
On the I/P above the radio
Inflatable Restraint Roof Rail Module - Left (ASF)
Above front and rear door rails behind headliner
Inflatable Restraint Roof Rail Module - Right (ASF)
Inflatable Restraint Sensing and Diagnostic Module (SDM)
Under the center console, behind the emergency brake
Inflatable Restraint Side Impact Sensor (SIS) - Left (ASF)
On the lower corner of the driver door
Inflatable Restraint Side Impact Sensor (SIS) - Right (ASF)
On the lower corner of the passenger door
Inflatable Restraint Steering Wheel Module Coil
On the steering column behind the steering wheel
You also need the secondary number to know what is failing.
DTC B0085 01: Left Front Side Impact Sensor Short to Battery
DTC B0085 02: Left Front Side Impact Sensor Short to Ground
DTC B0085 04: Left Front Side Impact Sensor Open Circuit
DTC B0085 0F: Left Front Side Impact Sensor Erratic
DTC B0085 39: Left Front Side Impact Sensor Internal Electronic Failure
DTC B0085 3A: Left Front Side Impact Sensor Incorrect Component Installed
DTC B0085 71: Left Front Side Impact Sensor Invalid Serial Data Received
Old Aug 8, 2009 | 08:42 PM
Gestapo007's Avatar
HAHAHA omg that was so epic
Old Aug 8, 2009 | 08:54 PM
snake890217's Avatar
I clicked to see *****! I demand them
Old Aug 9, 2009 | 07:32 PM
grahamSS33's Avatar
Hmm...where is the best place to get my car on a computer to get a more detailed description of the B0085 code? I know the dealer wants about $120 to run a diagnostic...so I want to stay away from that because I am pretty broke? Any ideas on what to do?
Old Aug 9, 2009 | 07:37 PM
sport08's Avatar
sorry i cant help but
i agree with Gestapo007 that was epic lulz
Old Aug 15, 2009 | 12:30 PM
Haith's Avatar
Think you could find a Thank you" somewhere for Coblasts very detailed answer to YOUR question?
That took a little time to put together.
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
jmelton327
Sep 26, 2015 10:04 PM
