Battery Dead
So my car is stored in the garage always is in the winter never gets droven so i go down to the shed to start it and nothing its dead......so i go to quick jump start it dead.......so i charge it for a while try it and dead........so i assume my batteries done for it....will gm cover this or not or will i have to buy a new battery and if so where do i get it at? :cussing:
When you store it do you put the alarm on? I store my car as well I start it atleast twice a week and id the weather is good I take it for a run.
I thought I read in my manual that the battery is only covered for one year but don't quote me! I hate those puny batteries they gave us.. Esspecially in :ca: winters.. Once mine died once it was worthless:thumbsdow
they're worthless batteries period
I forget how they cover the batteries at the dealer |
If it never gets driven in the winter... why don't you disconnect one of the terminals?
that wont screw up my reflash on my computer will it or anything
Originally Posted by olivecj
(Post 1857674)
dude, get a battery tender. they're usually used on like motorcycles and classics and so on, but they're like $20.
Originally Posted by joeworkstoohard
(Post 1857786)
exactly my thoughts. a battery tender will keep it up when its sitting for a long time. its one of those things you should put on at the time you put fuel stabilizer in the fuel. and still, should start it once a week and run it for a bit. |
where you get the tender at
gm covers the battery under 3year 36 as far as i know. at least at the dealer i work at we do.
Originally Posted by LaserBlue07SS
(Post 1857907)
give them a call. wish optima made a battery for our cars tho. If you store it put some sort of battery tender on it and when u do start it don't just start it and shut it down. worst thing you can do to a battery. take it around the block or something.
should be able to find a battery tender anywere you can buy a battery
If i'm not mistakin by disconnecting the battery for a long time will erase all fuel trim data right??
yeah the pcm will relearn the fuel trim so its ok you won't harm anything by unhooking a battery for an extended period
If you allow the battery to go dead ,it will then freeze and warp the plates,
Try bringing it inside for the night to unthaw and check it for 12 volt in the morning. If you have 12 volts in the morning charge it up and it might be still okay. And donot store the battery on cement keep it on a peice of wood. |
Check out this site... my battery just started giving me problems... its only a year old, but i got an insane sound system thats always draining it, plus winter is here and now thats showing the true effects. this list is having an impact on my decision for a new battery this weekend. hope it helps....
http://www.consumerreports.org/cro/c...eries-rate.htm |
