Originally Posted by Kesha Michaels
(Post 7424170)
Just so you know, there is a release for the trunk. Lower down your back seat and crawl to the back (hopefully you are not scared of small spaces) . You will see a white trunk release to pull. I have had this problem with not being able to unlock my trunk and needing to jump my car. Sounds ridiculous but... sadly is true.
on the fuse box is a positive post. put the jumper cables on that and a ground (normally strut tower) and jump from there
Originally Posted by Finelli714@gmail.com
How did your lower your seat to get into the trunk??
chev colbolt ,,whin trunk won,t unlock with dead battery ,,put the key in trunk lock
:ca:
Originally Posted by wudman
(Post 2371785)
2006 Chevy Cobalt
The battery is dead, the battery is in the trunk, and the trunk wont open. Not even with the key. Is there a trunk release leaver on the inside of the car somewhere? Or, is there a way to jump the car under the hood? If so, where are the terminals and what do they look like? Any other options would be appreciated. Thanks in advance |
put the key in trunk and peck on key to make it go in futher it will unlock trunk ,whin battery is dead ,,also red post under hood driver side ,charge ,,red on post black on strut nut ,will let u get key out of ignition and charge ur battery to ,,also jump start from there carl
