bottomed out and wont start
Old Aug 8, 2018 | 03:00 PM
AG305's Avatar
hey guys.
i live at a spot where my garage is down a steep ramp which normally i scrape the bottom of the front bumper a tiny bit if i dont turn the wheel and go down at an angle. my car is not in anyway slammed or nothing its just the nature of the beast. worst garage ever...
anyway, i got a flat real close by so i limped it back home and as soon as i went down the ramp i heard a huge metal hit and scrape like i hit the bottom frame or something up front which obviously had to do with one rim basically being on the ground. my car completely shut off and now does not run. cranks over, starts, does not stay on for more that 3 seconds. my first initial suspicion is i popped off a charge pipe or messed up my intercooler which upon inspection thankfully was not the case. theres nothing i can instantly and obviously see going on down there that would cause concern. no leaks or any fluids or nothing just a straight up bang and dead. only the front end hit so whatevers up front has to be the culprit im just at a loss here and have no idea whats going on.
any of you ever dealt with this or have any ideas? all help is appreciated. thanks!
Old Aug 8, 2018 | 03:07 PM
So I'm guessing you have a lnf do you have the stock intercooler?
Old Aug 8, 2018 | 03:09 PM
AG305's Avatar
yes lnf and not stock intercooler. its a zzp.
Old Aug 8, 2018 | 05:34 PM
What snail is going to say is that you probably busted your intercooler or piping. Check for boost leaks.
Old Aug 8, 2018 | 06:52 PM
AG305's Avatar
is it possible to bust the insides of it? cause nothing is visibly damaged from the outside and the piping looks great. its still my number 1 prime suspect though so i have no clue.
Old Aug 8, 2018 | 09:05 PM
Best thing to do is to do a boost leak test
Old Aug 8, 2018 | 09:24 PM
There is likely a significant boost leak, might not be the bottom of the intercooler but could be a connected pipe that came off from the force.
Old Aug 9, 2018 | 02:18 PM
AG305's Avatar
i dont have the means of doing a proper boost leak test right here. i plan on dropping the front bumper and inspecting further. i really hope i find something because this is very odd.
Old Aug 9, 2018 | 03:05 PM
AG305's Avatar
found the culprit! i knew it lol
now the question is... how much would a new core mess with my tune?
Old Aug 9, 2018 | 03:46 PM
Damn, that sucks.
A new intercooler should have 0 effect on your tune.
Old Aug 9, 2018 | 04:06 PM
AG305's Avatar
Originally Posted by ECaulk
Damn, that sucks.
are you sure? even if i go with a different brand/size? i plan on ordering a new one asap
Old Aug 9, 2018 | 04:11 PM
T-Man's Avatar
Goddamn bruh! I've smacked the hell out of my ZZP intercooler and nothing like that has happened... Just busted my radiator
New core won't affect anything. Good luck man.
Old Aug 9, 2018 | 04:16 PM
AG305's Avatar
yeah the crazy thing is it wasnt even that hard of a hit. rolled on in, and i guess the weight of the car all up on it did it in. it broke upwards for sure and that missing screw on the bottom definitely didnt help out either
Old Aug 9, 2018 | 04:26 PM
Lol that's crazy
Old Aug 9, 2018 | 05:22 PM
A different intercooler will not in anyway effect the tune.
Old Aug 9, 2018 | 05:40 PM
AG305's Avatar
ok thanks alot! imma get the ball rolling then.
Old Aug 9, 2018 | 07:29 PM
T-Man's Avatar
The missing bolt at the bottom is most definitely the reason it broke. Best of luck with a new one man!
Old Aug 20, 2018 | 04:05 PM
AG305's Avatar
got a new intercooler, installed it, car fired right up and everything is great BUT... now the crash bar doesnt line up. if it isnt one thing its another lol
did i miss something here? whats going on?
Old Aug 20, 2018 | 04:42 PM
Sharkey's Avatar
i would have just found somebody to weld it back up, would likely cost less than $100. might wanna consider doing that and selling it to recoup some funds.
Old Aug 20, 2018 | 05:16 PM
AG305's Avatar
is welding that spot a good idea? if its strong enough i might consider that.
Old Aug 20, 2018 | 05:48 PM
Kolt's Avatar
As long as you find someone who knows what their doing welding aluminum you wont have any issue. Itl be just as strong as before, just not as pretty.
Old Aug 22, 2018 | 10:56 PM
cobaltss#01's Avatar
Yeah man get it welded. I had to have my turbo xs intercooler welded on both sides. The seems had shitty welds and blew out. Nice thing about it being all aluminum.
Old Aug 23, 2018 | 01:15 AM
AG305's Avatar
well if i didnt already get a whole new setup i wouldve been down to just weld it. i was gonna replace it anyways so it was finally an excuse to do so.
if any of you guys are in the north jersey/jersey city area and want the core to weld it and stuff you can come take it. the charge pipe that goes with it to. merry christmas
Teetzel
Jul 6, 2015 11:21 PM
sherm420
Jul 18, 2012 10:16 PM
erikTC
Jun 26, 2012 02:30 AM
iboost
May 4, 2010 10:16 AM
