Burning hot trunk!
Old May 16, 2006 | 10:48 PM
Mercury's Avatar
Angry Burning hot trunk!
Um so yeah I had this problem before where the metal in my trunk right above the rear muffler gets hot in the interior. Anybody else have this problem?
After your car has been on for about 20 min go to your trunk and lift up the carpet and feel around on the left side near the subwoofer. (if equipped) Is it hot to the touch?
Old May 16, 2006 | 10:52 PM
joedashow's Avatar
Never checked, but I would imagine that would happen to any metal near any exhaust components. Just curious, what made you check that anyway?
Old May 16, 2006 | 10:53 PM
Mercury's Avatar
I heard a rattle then I noticed that. Very VERY hot.
Old May 16, 2006 | 10:57 PM
Sempher55's Avatar
you know what merc.. i think you are right... my left rear side gets hott.. i felt around when i was installing my dynamat.. i got home from work... which is a 30min drive, saw my dynamat from the ups guy... and started to pull up the material right when i got home from work.. and that ****** was hott... i thought it was just from the hot weather.
Old May 17, 2006 | 02:11 AM
05BlackCobaltSS's Avatar
Could this escelate (sp?) into a larger problem, like fire?
Old May 17, 2006 | 10:50 AM
3fo893013L's Avatar
What materials is the carpet made out of?
Old May 17, 2006 | 10:53 AM
Gorilla unit 33's Avatar
coulod the noise everyone hears be the trunk metal cooling down and tinging
Old May 17, 2006 | 10:55 AM
BLKSS's Avatar
I will get my tech guru to look at it tommorrow and find out exactly if it is a problem. Im worried about fire and damage it could inflict to my sub.
Old May 18, 2006 | 01:57 AM
Mercury's Avatar
I think it is a saftey issue as far as burning yourself.
Old May 18, 2006 | 06:32 AM
cvenom2122's Avatar
Thumbs up
jimmy go under the car and see if 1) piping is touching something 2) if the black coating is burned off exhuast may not be able to handle the exhaust temps (from supercharger)
Old May 18, 2006 | 06:34 AM
snobird's Avatar
didnt somebody sue mcdonalds for buring them seleves with coffee hint hint
Old May 18, 2006 | 06:47 AM
Brian MP5T's Avatar
A Heat shield would be easy to make and install.
Old May 18, 2006 | 11:28 AM
RedBaseBolt's Avatar
Thats not the point. If the car is like that stock it might be an issue.
If it's always like that and the same for all cobalts why wouldn't GM put a heat sheild there.
Old May 18, 2006 | 12:10 PM
cybcow's Avatar
LET IT BURN! That way insurance can buy me a new one : /
Old May 18, 2006 | 02:37 PM
Xenozx's Avatar
OMG my engine gets hot to the touch too, maybe I should be scared cause my hood gets hot when my engine is hot....
WTF
Man look, Hot to the touch can be like 120-130 degree's. We both know that aint startin no fire.
You where at the dyno that day with the lights dimmed down when my exaust turned bright red? IM sure thats going to heat up anything near it. I doubt it to be an issue and doubt any fire to come from it. If its an annoyance then get a heat shield like the Mazda guy said, if you wanna waste your time trying to get it addressed be my guest.
Old May 18, 2006 | 03:23 PM
Yikes12345's Avatar
Hopefully you're not storing anything under your hood though - the trunk is a different story. I haven't checked this on my car so I have no clue how big of a deal it is, but...you're much more apt to have something flammable in your trunk. Most aerosole (sp?) cans say to keep them under 120.
Old May 20, 2006 | 10:03 PM
Mercury's Avatar
WTF
Uh, Jeremy... It is a different story when there is carpet over this hot spot. Just as the other member said, you don't keep things in your engine bay. I just thought it was crazy that there is a part of my car inside the trunk that gets as hot as my muffler. I wasn't talking about my trunk lid...
Old May 20, 2006 | 10:18 PM
RaineMan's Avatar
That's very interesting.... I'll check it out next time I get back from a drive.
Old Oct 21, 2021 | 12:02 PM
Hvychvy07's Avatar
Can confirm its an issue! 2005 cobalt ls 2.2L
Old Oct 21, 2021 | 12:24 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Have you checked to make sure you don't have a hole in your exhaust that is blowing on that spot? Because that's my bet based on your picture.
Old Oct 21, 2021 | 12:32 PM
Hvychvy07's Avatar
I will be checking that tonight
RaginChopsuey
Oct 27, 2015 01:27 PM
camaromanss1992
Oct 1, 2015 10:51 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
