Camshaft Correlation Code
Old May 17, 2008 | 05:16 PM
Raven SS's Avatar
ive tried everything..ive tried adjusting the sensor..ive taking off the valve cover and put number 4 piston at tdc and aligned the camshaft sensor again and still nothing..anyone have an idea?
Old May 17, 2008 | 05:20 PM
originaladrian's Avatar
damn ur having allot of problems lately eh?
Old May 17, 2008 | 05:38 PM
Raven SS's Avatar
cuz i just got my car back after a complete overhaul
no one can help?
Old May 17, 2008 | 06:17 PM
jimbos'ss's Avatar
ask wsfrazier or witt.
Old May 17, 2008 | 06:20 PM
Sunburst_SS's Avatar
make sure cylinder 4 is TDC on the compression stroke.....line the mark on the sensor housing the the hex shaft.
There should be alignment marks on the crank damper and front cover if you're having an issue also
Old May 17, 2008 | 08:11 PM
Raven SS's Avatar
the build book says cylinder 1...i did number 4 and is the mark on the sensor housing look like a mark put into it
Old May 18, 2008 | 02:43 AM
jimbos'ss's Avatar
you get that **** fixed yet?
Old May 18, 2008 | 12:13 PM
Raven SS's Avatar
not yet dude...
Old May 18, 2008 | 12:41 PM
lil_kano's Avatar
you probably need to do a reflash or a crank case relearn.
Old May 18, 2008 | 12:44 PM
Raven SS's Avatar
i cant do a crankcase relearn until all codes are cleared....
Old May 18, 2008 | 12:51 PM
Red2.4SS's Avatar
Will it not work with Cylinder 1 at TDC?
Raven SS's Avatar
a cute picture...
Red2.4SS's Avatar
What codes are you getting?
Old May 18, 2008 | 12:53 PM
Raven SS's Avatar
everyone is saying cylinder 4 at tdc of compression...build says number 1..they are at tdc together but when 4 is on compression 1 is on exhaust
p0101 maf performance
p0017 camshaft correlation code
p0315 crankcase relearn
Old May 18, 2008 | 12:56 PM
Red2.4SS's Avatar
Well cant hurt to try it again with the crank spun another 360*. Get 1 to TDC and try it out. Typically #1 cyl is the standard for setting an engine.
The camshaft rotates at half the speed of the crank so that could be why it isn't working with 4 @ TDC.
Those other codes like you said you can deal with after.
Old May 18, 2008 | 12:58 PM
Raven SS's Avatar
The camshaft rotates at half the speed of the crank so that could be why the sensor is off.
tearing apart the valve cover and lining it up is ftl in 90* weather lol..i dont have reverse in my car right now so i cant pull in my garage cuz my driveway is a hill
Old May 18, 2008 | 01:03 PM
Red2.4SS's Avatar
Call out the crew! Make em push! HAHA!
I am guessing that is the problem, the cam sensor is likely 180* off.
I am not an ecotec expert, but i have worked on other engines!
Old May 18, 2008 | 01:05 PM
Raven SS's Avatar
yea it might be...will see
Old May 18, 2008 | 01:12 PM
yes, cyl. 1 and 4 would be at TDC at the same time.....just on different strokes. You need to have cyl 4 at TDC on the compression stroke, which should put cyl. 1 TDC on the exhaust stroke.
Old May 18, 2008 | 02:31 PM
jimbos'ss's Avatar
have you tried disabling those codes and then running a case learn? idk if it will work, but worth a try imo.
Old May 18, 2008 | 02:57 PM
Raven SS's Avatar
disabling the code doest clear them..just causes the cel not to pop on the dash..so when they plug in the tech 2 its still there...
Old May 18, 2008 | 03:29 PM
jimbos'ss's Avatar
damn.....
Old May 22, 2008 | 02:28 PM
06blackg85ss's Avatar
we got another car doing this right now, anyword on the fix? did a case relearn and the CEL hasn't popped back up, but the car is still a pita to get it to start.
Old May 22, 2008 | 03:10 PM
How did you put the camshaft sensor in???
Old May 22, 2008 | 03:21 PM
*TRIX*'s Avatar
yeah my car is doing it right now after we redid the pistons and i cant get it to relearn itself help :/
