Can't get the Key out
Old Jun 15, 2008 | 04:37 PM
hinow41's Avatar
Angry Can't get the Key out
I have a slight problem. I drive a 2.4 and its auto. My problem is that every time I go some were and put it in park I go to turn off the car and It wont let me take the key out. I have to push up on the shifter hard and then I can some times get the key out anyone know what the problem could be? I really don't want to take it to a dealer because I have alot of extra stuff Iv done to the car.
Old Jun 15, 2008 | 04:38 PM
iLLmaTic3s's Avatar
yep common problem on the cobalts..bring it to the dealer..they will fix that problem
Old Jun 15, 2008 | 04:59 PM
hinow41's Avatar
Dam. Do you know what they do? I have a lot of wires under my center console. I just don't want them to brake anything.
Old Jun 15, 2008 | 05:01 PM
madmark's Avatar
its a sensor on the right side of the shift assembly, its a cheap design and when the bracket breaks it will not let the bar return to its original position. when it doesnt return it shows that the vehicle is not in park and will not release the key
and what we would do is, remove the top cover. pull the 4 13mm bolts holding it down, releast the shift cable and walla! its out
Old Jun 15, 2008 | 05:02 PM
Raiden8816's Avatar
this happened to me. its the shifter linkage. it gets worn out, they will have to replace the entire shifter assembly.
Old Jun 16, 2008 | 07:47 AM
xfemannuel's Avatar
This happend to my HHR. i lived with it. i just traded it in for a cobalt.
Push toward crank and then try to get it out worked for me. btw i couldnt over crank my HHR dont know about auto balts.
Old Jun 16, 2008 | 08:12 AM
SilvrLT's Avatar
Same here the cobalt wont let you grind the starter
Old Jun 16, 2008 | 08:17 AM
originaladrian's Avatar
this happend to me when i first got my car an kinda jerry riged all my electronics up. Once i totally redid everything the right way my key stoped getting stuck... idk if this will help you...
Old Jun 16, 2008 | 08:20 AM
jeremie's Avatar
all the dealership will do is replace the shifter assembly. and it will be ok.
Old Jun 16, 2008 | 09:36 AM
hinow41's Avatar
Thats what they did. I called to day went in at 8 was out by 9
Old Jun 16, 2008 | 11:34 PM
Mr_Slobalt's Avatar
yep, new shifter assembly....bad BTSI
there's a spot under the steering column that you can jam a small screwdriver into to release the key...I believe it's a white plastic piece...you'll have to remove the cover first
satisfied
Oct 19, 2015 12:35 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Shane H
Sep 20, 2015 11:56 AM
Gugi96
Sep 15, 2015 12:24 AM
jthwjde
Sep 7, 2015 09:24 AM
