Car Bogs & goes into Limp Mode-Help Please!!!!!!!!
Here's the deal, when I go to give my car about half throttle it bogs down and instantly goes into limp mode. Not sure what the problem it but it just randomly started lastnight on my way home. The car also will hold rev's in between shifts and idle sporadically.
Here are the codes she threw:
P0121 Throttle Position (TP) Sensor 1 Performance -PCM
P0140 HO2S Circuit Insufficient Activity Sensor 2 -PCM
P0141 HO2S Heater Performance Sensor 2 -PCM
P0068 Throttle Body Airflow Performance -PCM
P0069 Supercharger Inlet Pressure (SCIP) - Barometric (BARO) Pressure Correlation -PCM
Any help will be appreciated.
Nobody?
Cmon
Yep, how bout that response...
Nobody?
Cmon
Last edited by Rangerondubz; Jan 28, 2009 at 10:07 AM. Reason: Automerged Doublepost
After more testing it seems not to bog but when I give it gas it takes off then jerks the car b/c it goes into limp mode.
This blows
This blows
Last edited by Rangerondubz; Jan 28, 2009 at 11:16 AM. Reason: Automerged Doublepost
when u get the codes checked / eraced they should be able to tell you what could caust alll of them to fail like that. ( i had this problem but not as many codes... mine was a cloged cat. ) which inturn the cat could be cloged and not leting the rest of the intake or inlet side of the motor breath.
I had the throttle position sensor code when the connector that goes into the throttle body got disconnected
And it also put the car into limp mode.
That could be part of it
Idk about the rest of the codes though
oh oh i can maybe help lol!
my car did this before. i turned the car off for about 5 minutes then turned it back on and it was fine.... i took it to the dealer and they said it was the Throttle body but it seemed fine now.... so after it did it again we found out that after boosting hard and letting off the gas to fast it jammed the TB shut and it got stuck for a sec causing the car to panic and go to limp mod
and judging by your codes its the same
But here is the thing, I clear the codes w/ my interceptor then I can give it gas and it will do the same thing again. Also runs like total ass w/ in Limp
I think it may be the Throttle body, it will only do it if I give it half to full throttle at any RPM. Also it will hold revs during a shift or when I am in neutral so im thinking that it may just be dirty.
Still open to opinions though.
Let me get some responses people
Last edited by Rangerondubz; Jan 28, 2009 at 12:56 PM. Reason: Automerged Doublepost
your TB could be jammed...... that was part of my problem, the only reason it just went away was because it freed its self up but if it didnt it would have kept running like yours. take your TB off and look and see if there are marks from the valve getting jammed
Got it fixed! Yes Redline there were marks from it getting jammed. But I took the intake coupler off and shot a few sprays of TB cleaner and move the butterfly alittle myself, then put the coupler back on a voula. Thanks for the tips Redline they helped me out.
Thanks all.
Thanks all.
hey man glad i could help you, it could still do it again, so i would get a new TB or if you have warrenty they will just put a new one in, no questions asked. if not then go for LS4 tb haha
whats this about
whats this about
Last edited by red_line_cobalt; Feb 4, 2009 at 09:10 AM. Reason: Automerged Doublepost
hum good to know you got it fixed man! hows those konis btw? I am having a somewhat similar problem, I give it throttle, and it jerks like somethings holding it back then picks up and goes, almost same codes, going to try taking tb apart under warmer weather.
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
