car jerks on accel
Old Apr 24, 2011 | 11:26 AM
Drew.4L's Avatar
car jerks on accel
from first gear going into second, the car jerks when i try to floor it, or just go heavy on the accel. i thought it was my filter or my intake, but i looked at it and the gasket was fine.
no CEL no nothing.
it tries to pick up in first gear and it just... well its hard to explain. when it gets into second tho its fine.
i have an auto... anyone have similar or know what it could be? the tranny? im only at 60,000+ miles
Old Apr 26, 2011 | 07:21 PM
Drew.4L's Avatar
no one?
Old Apr 26, 2011 | 08:19 PM
cobalt2010's Avatar
does it jerk like its losing spark or fuel?
Old Apr 26, 2011 | 09:17 PM
Drew.4L's Avatar
the speed? if i slowly put my foot on, its hardly noticeable, but when i want to jet from zero, theres heavy movement, like it wants to but something is holding it back in that gear. once it up shifts its fine.
ive never gotten it down to where i had no fuel, also, idk what it feels like to not have a lost spark.
Old Apr 26, 2011 | 11:30 PM
CelphTitled's Avatar
plugs??? maybe a misfire???
Old Apr 26, 2011 | 11:32 PM
northvibe's Avatar
well...what engine and transmission? what mods? do you have a tune? do you have a CEL?
Old Apr 26, 2011 | 11:34 PM
Chevycobaltss3's Avatar
actually if the car jerks but it does get to speed it can be one of the many things. injector, fuel pump, spark plugs, maf sensor, cam sensor, ecm, tranny , tcm, coil or plug wire, sucking in water, dirty air filter, bad wire connection, bad short in ecm connecter or chasis, and more. Usual is the maf sensor failing itll usually throw a maf code or the injectors.
Old Apr 27, 2011 | 08:26 AM
Drew.4L's Avatar
ill give some of those things a look.
if ur asking what trans, im an auto like is says at the top...
no mods cept the air well delete. not much of a mod.
no tune bone stock
Old Apr 27, 2011 | 08:33 AM
YelloEye's Avatar
Violent jerking or just power "spurts"?
Old Apr 27, 2011 | 08:39 AM
Drew.4L's Avatar
power spurts sounds pretty accurate. its trying to build speed, but it spurts doing it, untill second gear.
Old Apr 27, 2011 | 09:48 AM
06G85's Avatar
Maf
Old Apr 27, 2011 | 05:37 PM
Drew.4L's Avatar
ill give it a look
Old Apr 27, 2011 | 05:45 PM
LS6Rally's Avatar
Check maf, and im also leaning towards a fuel filter
Old Apr 27, 2011 | 05:50 PM
Drew.4L's Avatar
and where is that located? does it help to mention i variated on diffrent levels of octane fuel? only when im runnin close to empty tho
Old Apr 27, 2011 | 05:55 PM
This sounds like fuel pump. Since the pump will get warm whwn theres no gas ro keep iit cool unless ure fuel filter is bad
Old Apr 27, 2011 | 05:58 PM
Drew.4L's Avatar
well, idk whre the fuel filter or pump is, but i checked the maf and it looks really dirty. im going to try and clean it, with a q tip, should be ok right?
Old Apr 27, 2011 | 06:00 PM
LS6Rally's Avatar
Fuel filter is on the underside of the car above the rear axle.
Old Apr 27, 2011 | 08:33 PM
Drew.4L's Avatar
ahh ok. well i bought a new airbox filter and started it up, looked under the hood with it running... touched the MAF sensor.... and my car choked and almost died. hahaha i think i know what the problem is
Old Apr 28, 2011 | 05:57 AM
YelloEye's Avatar
Makes sense if you touch the MAF sensor opening the car thinks it's getting less air and cuts back on fuel when in reality its still getting the air and leaning out a ton.
Old Apr 28, 2011 | 08:39 AM
Drew.4L's Avatar
i didnt touch the opening , thats the thing. i touched the wiring harness while the sensor is still in place, where the wires connect to the sensor itsself. and it choked
Old Apr 28, 2011 | 08:49 AM
hunter19707's Avatar
Don't touch the sensor wires on the maf, just get some maf sensor cleaner and spray it down real good. You should never touch the sensor wires, even with a q-tip.
Old Apr 28, 2011 | 10:18 AM
YelloEye's Avatar
Sounds like you have a wire loose or something, though the car shouldn't completely die. My car will idle (terribly) if I unplug the MAF.
Old Apr 28, 2011 | 10:37 AM
Drew.4L's Avatar
yeah ill investigate further after a nap. ill be home all day. i should call CTI also, that ****** willie is taking a month + with my over mother over ****** axel pipe
Old Jun 5, 2011 | 10:20 AM
blackdew21's Avatar
my lsj does the same thing with no cel. When I give it gas and let off of it.. It's not to bad but I can stand it. Guys at my shop told me it could be mount? I had it in right after a misfire, after that the cel went off. Tyis was about 4 months ago. Car old has a intake and catless dp.
Old Jun 5, 2011 | 10:30 AM
If u have a intake and ect and u r not tuned for it invest in a tune. Fuel trIm can be outta wacky...
