Car jerks when driving slowly
Old Dec 13, 2007 | 10:02 AM
Adirondack_Cobalt's Avatar
i think it's the way the engine management is. My father had an 89 Mustang GT that was the same way in traffic, parking lots, etc... these cars just don't like slow!
Old Dec 14, 2007 | 12:15 AM
rukkee's Avatar
Originally Posted by roadrage06
what he said.
haha... you are all talking about getting it fixed like it's a malfunction. the only mod that is going to fix this is the driver mod. ease out on that clutch and control yourself in that annoying ass stop and go traffic. i've had it from time to time, but i realize it's my own dumb fault and not the cars.... push the clutch back in when it starts to do it and try again.... this time with more finesse.
All the finesse in the world wouldn't stop my car from doing this . The car is idling threw a parking lot in 1st gear clutch all the way out , if you even touch the gas 1 millimeter it jerks , same if you let off . I don't like to have to ride my clutch just to go a steady 5mph, and thats the only way to stop it .
Old Dec 14, 2007 | 12:17 AM
EceSSiveMod's Avatar
my car does that because my clutch releases really high, idk about urs tho
Old Dec 14, 2007 | 12:41 AM
chris88z24's Avatar
You don't have to ride the clutch.. I can takeoff without giving my car any gas at all, and it doesn't jerk. Be EASY with the gas!! If I hit the gas too hard and clutch jerkily the car will buck and be a piece of ****.
Old Dec 14, 2007 | 01:35 AM
liolixli's Avatar
I think a lot of guys are missing the point or don't have the same problem. It isn't driver error since giving it gas or not isn't effecting it. If I just try to coast down a hill at 5mph or less my idle alone is jerking all around and that is with no driver input, so it is the car not the driver.
Old Dec 14, 2007 | 09:29 PM
Dispute's Avatar
My LT does this also, and so did my 94 sunbird. Its good to see its not just my driving.
Old Dec 15, 2007 | 12:08 AM
eastcoastz's Avatar
I know for a FACT its not my driving! I've been driving this car for over 2 years and this started to happen one day after I was doing 6 HARD pulls with an Sti that would not quit because he could not take the fact that a Cobalt was pulling on him. I think my meth injection might have have damaged my throttle body, TPS, or MAP causing a bad reading. I take my foot off the gas and it feels like a bang or shock to the drive line. Sice then I've found a bad intake leak caused by rubbing(fixed), fixed my leaking exhaust, and replaced MAF, Plugs, O2 sensors, Supercharger. Like I said before tho if I unplug the coolant temp sensor to force the car to run in OPEN LOOP the car runs just like it use to PERFECT! ITS NOT MY DRIVING
Old Dec 15, 2007 | 12:24 AM
68nova200's Avatar
just let the engine pull the car along in first if you want to go that slow. dont use any gas. that usually helps it for me
Old Dec 15, 2007 | 12:44 AM
eastcoastz's Avatar
Can't do that anymore it bucks and jerks badly.
Old Dec 15, 2007 | 12:48 AM
liolixli's Avatar
Exactly what I was saying. You can't even get it to not jerk with no gas coasting. I'm glad you brought up your temp solutions. Maybe, with enough input something will come out useful.
Old Dec 15, 2007 | 12:51 AM
  #36
68nova200's Avatar
just experiment with it. but personally i like to go fast!
  #37
lsjwannabe's Avatar
Why do you coast at 5mph, do youguys drive only to parking lots or something? Whenever i start to feel it buck i just push the clutch in and coast it works fine for me.
Old Dec 15, 2007 | 12:53 AM
  #38
eastcoastz's Avatar
I was I had money to just blow cause I would buy a new MAP and throttle body assembly because I think my meth fucked me. Are running meth??
  #39
lsjwannabe's Avatar
yeah, the meth did not do it. If the meth caused a big problem your car would not be moving now.
Old Dec 15, 2007 | 01:01 AM
  #40
eastcoastz's Avatar
Not true at all bro. My friends SS crushed 3 lifters and was running smooth with NO CEL for 2 weeks until I brought it into my shop and removed the valve cover and found 3 CRUSHED lifters and the roller rockers laying in the head. As a matter of fact 2 chevy dealers told him nothing was wrong with the car and to bring it back if the CEL comes on.
Old Dec 15, 2007 | 01:03 AM
  #41
lsjwannabe's Avatar
You ever think its that intake? Is it a oiled filter? Oil on the maf can be a pita
Old Dec 15, 2007 | 01:09 AM
  #42
rguti153's Avatar
same here ......i thought it was my fault for learning how to drive stick on this car....i thought i was ******* up but i guess is just not me ......but getting the hang of it ....cause ...houston ....traffic ...all the time
Old Dec 15, 2007 | 01:13 AM
  #43
eastcoastz's Avatar
No oil on the MAF at all. Just to be safe I replaced the MAF a month ago.
Old Dec 15, 2007 | 01:14 AM
  #44
liolixli's Avatar
No, but the car works fine for me driving it normal. It is only in those situation where it happens, but it is annoying. I do spend a lot of time in slow conditions though. The point is that I want to be able to drive normally. Sure, I can get on it a little and avoid that; however, that is usually the time the police are in the parking lot too and wonder what you are doing and think you are provoking them not going easy with them there.
Old Dec 15, 2007 | 01:16 AM
  #45
berto's Avatar
myspace.com/jvcougar
YEAH ALL COBALT SS/SC's TEND TO DO THAT
DON'T WORRY ITS NORMAL
BUT DON'T ASK ME WHY THOUGH
Old Dec 15, 2007 | 01:21 AM
  #46
eastcoastz's Avatar
Well mine if I let off the throttle even in higher gears its like theres excessive drag on the engine.
Old Dec 15, 2007 | 05:07 AM
  #47
rukkee's Avatar
Dude did u read what i wrote?? With clutch already out , has nothing to do with clutching the car.
There are times when you can't go 10-15 mph , like rush hour , speed bumps or people walking next to your car . I'm not saying it can't be fixed by pushing in the clutch , but for a new car these things have the characteristic's of a 78 mack dump truck .
Old Dec 15, 2007 | 07:03 AM
  #48
chris88z24's Avatar
It also has to do with the computerized throttle ie. drive by wire. Ever try to stall in 2nd by taking your foot off the gas and coasting? It won't stall, the computer will give the car gas even though your foot is completely off the pedal.
Old Dec 15, 2007 | 01:42 PM
  #49
ptrblkz24's Avatar
So i guess youve never driven your car in traffic huh?Try driving in nyc traffic,youll see what im talking about real fast.
To the other clowns that have no idea what we're talking about,its not driver error.The car is bucking when ur foot is on the pedal cruising at steady speed.This car doesnt like cruise smoothly at low speeds.
Old Dec 16, 2007 | 02:07 PM
  #50
eastcoastz's Avatar
ptrblkz24,
What modds do you have? It sound like we are have the same problem. Try doing what I did and warm the car up and unplug the coolant temp senor and take her for a little cruise. The problem is gone when I do that, but you don't want to be driving around like that too long.
