Car locked up?
Old Nov 25, 2011 | 02:03 PM
sjc0013's Avatar
Window Licker
Car locked up?
My car refuses to start up. When I try to turn it over it keeps clicking and the lock light on my dash keeps lighting up. I still have my radio and all other power but my car wont turn over. I searched some other threads and found that it may be the battery? But then why is the lock icon lighting up? The battery is on the charger now so hopefully its just that. All i did was change my oil haha, when i first went to start it up after the oil change it did sputter, so i shut it off, started it again, and everything was fine. Then 10 minutes later i go to leave my house and the bitch wont start up. Anyone got any suggestions?
Old Nov 25, 2011 | 02:07 PM
SlowCobaltSS's Avatar
The first time I had my oil changed in the car it did the same thing and after looking around for a little I found that the sensor right by the oil filter cap was not plugged back in (I dont know what sensor it is tho) Maybe check that.
Old Nov 25, 2011 | 02:17 PM
sjc0013's Avatar
Window Licker
Looks like all my sensors are plugged in, I've had the battery on the charger for a while now as well and it still refuses to start up
Old Nov 25, 2011 | 02:19 PM
Maybe one of your sensors took a **** on you,
Its just cranking over and over right?
Old Nov 25, 2011 | 02:21 PM
sjc0013's Avatar
Window Licker
It sounded like it wanted to turn over, but it didnt and it just keeps clicking with the lock light popping up
Old Nov 25, 2011 | 02:23 PM
Stupid thing to say on my part,But try to push start it maybe the starter is locked up.
Old Nov 25, 2011 | 02:33 PM
sjc0013's Avatar
Window Licker
Did some more reading, looks like it could be a security issue for some reason, great
Old Nov 27, 2011 | 04:56 PM
09silverSSS's Avatar
Sounds like a bad cell in your battery. Mine did the same thing. The security lock light would come on and it wouldn't crank. Eventually no dash lights came on. I ended having to buy a new battery.
Old Nov 27, 2011 | 05:45 PM
sjc0013's Avatar
Window Licker
Im not sure what it even was, I let it sit for another 30 min and then went out and it started right up, its been perfectly fine ever since
Old Nov 28, 2011 | 12:57 AM
06SS ALL DAY's Avatar
put it on accessory. roll up to like 5mpg annnnd pop start it. u wont kill anyone doing that and youd probably if at all just have to push it back to ur driveway or w.e.
Old Nov 28, 2011 | 01:18 AM
InfraRedline's Avatar
Sounds like an ignition switch issue. A few of these threads pop up every year it seems right when the weather starts gettin cold. If it keeps happening replace the ignition switch and do the security relearn.
Old Nov 28, 2011 | 10:36 AM
sjc0013's Avatar
Window Licker
Thanks for the input guys, I will keep that ^ in mind if it starts acting up again.
chefhhr
Oct 26, 2015 10:36 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
brickloaf
Sep 6, 2015 05:55 PM
