car shuts off
car shuts off
Well for some reason when i have the car on but not running it will die after a few minutes. It wont come back on for atleast ten to twenty minutes no matter what i do. I was just wondering if anyone else has had this problem or knows why it does that. Thanks for any help.
Could be load shed for your battery voltage being too low.
If you have an interceptor Check your battery voltage on your interceptor. Should be about 12VDC
I've seen mine as low as 11.9 or 11.8
Have your battery checked. Also check loose and/or corroded connections. If good, have your
battery chargeing system checked.
brickloaf
Sep 6, 2015 05:55 PM
