car is stuck on!! running outta gas!
Old Feb 20, 2011 | 03:00 PM
CudaJoe's Avatar
Welp... my key is locked in the ignition... its Sunday and no help from the dealership for me... the car is on and I can't shut it off.. anyone experience this? Any clues how to turn it off?
Old Feb 20, 2011 | 03:03 PM
1LowLS's Avatar
if you dont wanna run it out of gas un hook the battery and itll shut off.As for taking the key out,theres a removable cap on the bottom of the steering column,take that off and there a button you can push while twisting back on the key,it should release the ignition
Dirty25RS's Avatar
pull the fuel pump fuse. its safer than trying to disconnect the battery
be safe, dont get shocked.
Old Feb 20, 2011 | 03:04 PM
Garret's Avatar
the alternator will keep it running.
Just stall it ?
Old Feb 20, 2011 | 03:05 PM
1LowLS's Avatar
That will work too,If you pull the fuel pump fuse,it'll pop a code for the fuel pump circuit,that's normal.
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
stall it...
Old Feb 20, 2011 | 03:06 PM
1LowLS's Avatar
Just stall it ?
No it wont.There is too much electrical demand for just the alternator to run the whole car
Old Feb 20, 2011 | 03:07 PM
1LowLS's Avatar
Either way your gonna have to unhook the battery if the key doesn't turn off otherwise you'll kill the battery.
Garret's Avatar
My car has run on alternator countless times
Old Feb 20, 2011 | 03:23 PM
TommyP's Avatar
AWD > FWD
Wouldn't it have to be able to? Otherwise you would drain the battery when you drive it? Just thought that made sense.
Old Feb 20, 2011 | 03:24 PM
1LowLS's Avatar
really?I never tried in my balt but the caddy and the s-10 had too much demand for just the alternator to run it infact my s-10 the ECU solely ran off the battery.Had the alternator tested multiple times in both cars and was 100%.just figured the balt was like that too.
Garret's Avatar
lol good point
Old Feb 20, 2011 | 03:27 PM
mongorat427's Avatar
Sounds like my old lady. Thats why I got rid of her.
Old Feb 20, 2011 | 03:29 PM
1LowLS's Avatar
What?
Put the Ebrake on and stall it with the clutch then disconnect the battery
Old Feb 20, 2011 | 03:34 PM
frankiess's Avatar
x2
Dart_SI's Avatar
common sense = stall the ****. put it into 5th gear and simply let off the clutch. or pull the ebrake and put it in first. problem solved, for now.
Old Feb 20, 2011 | 05:19 PM
Cobalt08LS's Avatar
stall it like everyone else is saying.
Old Feb 20, 2011 | 05:30 PM
1LowLS's Avatar
Pee in the intake? jk
Old Feb 20, 2011 | 05:40 PM
Malaclypse's Avatar
Easiest way is to remove the three 7mm screws from the lower cover of the steering column and unplug the green connector going to the ignition switch.
That kills the car and all electrical power.
Old Feb 20, 2011 | 05:50 PM
1LowLS's Avatar
There's a button on the bottom of the column made for this problem.Pull the little cover plate on the bottom,Press the button,turn off car,take to dealer tommorrow.problem solved!
Old Feb 20, 2011 | 05:59 PM
Switt23's Avatar
Unhooking the battery while the car is running is a horrible idea. You are correct it will inturn kill the car after a few moments, but that's like putting a fat man on a treadmill running full blast.
Also while the car is running the alternator will be supplying current through the wire harness, risk of damaging the alternator or other parts of the vehicle with a live wire... ever grounded out a power wire before? Ever Arc welded and not scratched your rod before starting... If your wire gets grounded out and the alternator puts out enough current to keep the car running for a couple minutes... kiss your alternator good.
Put it in 5th, let the clutch out and kill it. Then pop the panel off and press the emergency release on the ignition switch and take the key out.
Old Feb 20, 2011 | 07:16 PM
Cobalt_Daddy's Avatar
ya there is a bulletin about this... not a recall but dealership should install the newer style tumbler... im taking mine to the dealership as soon as it's out of storage and telling them the ignition sticks sometimes so they'll replace it now before the same thing happens to me..
i agree don't disconnect the battery... just stall it or use the button under the cover on the steering column.
Old Feb 20, 2011 | 07:18 PM
myfakeevo's Avatar
cut the brake lines, drive into wall. that'll teach the car a lesson
Old Feb 20, 2011 | 07:23 PM
JGoodman07SC's Avatar
its a spring in the ignition , when spring breaks it locks the key in , GM's fawl to every car , happened in my cav happened in my balt
