Car won't start after WOT box installation Please Help!
Old Jun 1, 2014 | 12:37 PM
blackwhine622's Avatar
I recently installed a N2MB WOT box and a 3in ZZP intake and now my car won't start. I double checked all of the WOT box wiring and it is correct and all of the connections have been soldered. I had the blower off and injectors out for some maintenance also but that has all been properly reinstalled. I know it is getting fuel as the plugs were soaked whenever I took them out. Anyone have any suggestions as to what could be wrong? Thanks!
Old Jun 1, 2014 | 12:39 PM
TStone's Avatar
Something with the wire that goes to the ign stuff. Probably not getting spark.
Old Jun 1, 2014 | 12:47 PM
That's what I was thinking. How would I check for spark?
Old Jun 1, 2014 | 01:09 PM
TStone's Avatar
Um well i'm assuming you don't have a spark tester. Just cut the wire that runs from the wot box to the ign signal. It should start then..
Old Jun 1, 2014 | 01:13 PM
chris88z24's Avatar
Is the WOT box plugged in? I noticed if you unplug the wot box the car won't start...
Old Jun 1, 2014 | 01:38 PM
Yes the WOT box is plugged in. The WOT box originally came off of a different car.
Old Jun 1, 2014 | 02:26 PM
Update: I unplugged the WOT box and jumped the red and black ignition coil power wires and now it will start for a second or two and then it dies.
Old Jun 1, 2014 | 05:04 PM
09outlander's Avatar
Step 1: remove WOT box
Step 2: throw WOT box in the garbage
Step 3: rewire your car to it's original design
Step 4: shift the car normally at WOT throttle, the same way people have been doing it since manual transmissions were invented.
Old Jun 1, 2014 | 06:00 PM
Good one. Thanks for the help.
Turbo Johnny
Feb 21, 2019 09:41 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
ashalle2
Sep 16, 2015 10:36 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
