car wont start.... again!!
Old Sep 24, 2011 | 02:47 PM
damastah's Avatar
same problem i had a few months ago.... all connections i checked, there good... i have not checked the starter motor... yet...
Cobalt wont turn on - YouTube
i gotta go to work!
Old Sep 24, 2011 | 03:07 PM
xbobbitox's Avatar
Have you brought it to the dealer? That's warranty ****
right there
Old Sep 24, 2011 | 03:12 PM
05Slowline's Avatar
check coil packs? nice shoes lmao.
Old Sep 24, 2011 | 03:40 PM
damastah's Avatar
HAHA i knew someone was going to say something... there my dads i just threw on because my sandals were downstairs.
jumped the car !!! and it lives! wierd because multimeter read 12 volts....
now i need to look for a vat 45 to use for free!
Old Sep 24, 2011 | 03:49 PM
jlong3382's Avatar
Probably a dead cell in the battery. Do a load test to see if the battery is readily able to hold a charge. If you can jump start it, it's not the starter. If the battery reads 12V-14V when it's running, that's normal because the alternator is charging it.
Old Sep 24, 2011 | 04:04 PM
05Slowline's Avatar
mine reads 13-14 when running
Old Sep 24, 2011 | 05:41 PM
Coblasts's Avatar
Check the voltage on the battery while someone tries to start it.
You need a big load on it otherwise you are reading residual voltage.
When cars running you should read between 13 and 15 volts dc ,has to be higer than 12 to charge the battery!
Old Sep 24, 2011 | 05:56 PM
hydroturboss's Avatar
i think u need to jump start your RPD!!!!!
im so SMART!
Old Sep 25, 2011 | 12:18 AM
damastah's Avatar
yea.... im going to see if i can borrow a friend's vat 45. ill do a load test. and i will check my alternator as well... im sure the alt is fine, rpd reads 13-14 volts while running. which is a lil low for me tbh. but it should be fine. i think if i just do a nice slow charge over night, battery should be fine.
Old Oct 20, 2011 | 09:21 PM
06'BlacKSS/SC's Avatar
in for this mines doing the same thing
Old Oct 20, 2011 | 09:50 PM
damastah's Avatar
hahahaa.... do you have a radar detector??? i realized leaving mine in the car, even tho the radar detector was off, if its still in the car, it acted as a parasitic drain when the car is off...
also, open your trunk, take spare out, and feel the carpet on the bottom of the trunk. is it wet?
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
no_ss
Sep 18, 2015 11:03 AM
