Car wont stay running
Old May 21, 2012 | 08:28 AM
Maccoy316's Avatar
This morning I get ready to head to work and start my car. Idles under 1000RPMS and dies out. So I start it again and play with the throttle, barely revs and then dies out. Ended up taking the R6 to work but would much rather have drove the SS. Anyone have any ideas what I should check when I get home?
Old May 21, 2012 | 09:16 AM
Maccoy316's Avatar
I know it's early so get that cup of coffee in you and send me some suggestions lol.
Old May 21, 2012 | 09:20 AM
07LSJ's Avatar
i have no idea so free bump for you
Old May 21, 2012 | 09:30 AM
1AJeremyD's Avatar
Any check engine lights? When was the last time you cleaned the throttle body? Any unusual noises coming from the engine?
Old May 21, 2012 | 11:21 AM
Maccoy316's Avatar
no engine lights, and I've never cleaned the throttle body but thats a good suggestion.
Old May 21, 2012 | 11:24 AM
1AJeremyD's Avatar
It would be where I would start since you said that the car revved slowly. Any unusual noises? Also have you done any work to the car recently?
Old May 21, 2012 | 01:41 PM
Maccoy316's Avatar
no haven't added anything to it in a long time as far as performance. But I do plan on getting a Tune from Trifecta and hope that helps a bit.
Old May 21, 2012 | 02:17 PM
MoJoJoSSsc03's Avatar
x2 on the TB check... and if you painted you tail lights green.. maybe thats the car saying it doesnt wanna go out like that....
Old May 21, 2012 | 02:23 PM
Maccoy316's Avatar
haha no my car is blacked out completely lol.
Old May 21, 2012 | 02:36 PM
2010Cobalt's Avatar
See if you are getting fuel. Kinda sounds like a fuel issue. Bad pump? Fuel filter dirty? Air filter shot? Bad plugs.
Old May 21, 2012 | 02:41 PM
O9cobaltSS's Avatar
this JUST happened to my buddy, engine would idol like it had a crazy lift cam in it n then to the point were it just would not stay running. brought it to the dealer and found out his ECU was fried and it was covered uder warrenty. time to bring her in!!
Old May 21, 2012 | 02:49 PM
Maccoy316's Avatar
my car wont go anywhere lol, it'll run for a few seconds before it dies. I was thinking it could be a fuel issue. I'll check my plugs when I get home.
Old May 21, 2012 | 03:33 PM
Coblasts's Avatar
When you turn the key on can you hear the fuel pump prime and shut off.
(turn the ignition on with out trying to start it and see if you can hear it)
If not go to the back of the car and kick of hit the gas tank where the fuel pump is and then try to start it again!
Old May 21, 2012 | 03:40 PM
Maccoy316's Avatar
I'll give that a shot as well.
Old May 21, 2012 | 03:59 PM
1AJeremyD's Avatar
Did this just start occurring out of nowhere or have to been having stuttering issues prior? Have you changed out the fuel filter at all? mileage?
nwss's Avatar
diconnect the battery for a few then connect it(reset the ecu), maybe check your maf or map, if you rev your car up does it stay running?, and when you turn the ignition on (not car) can you hear the tb do its cycle?
Old May 21, 2012 | 04:06 PM
Maccoy316's Avatar
after I rev it, it still dies out. Milage is around 44k and I have never replaced the fuel filter. Every now and then I'd get the flutter issue and assumed that was due to my GMS1 and the connections like everyone else.
Old May 21, 2012 | 04:52 PM
nwss's Avatar
well if its gms1 just call the dealer, is it still under warrenty?
Old May 21, 2012 | 07:02 PM
2010Cobalt's Avatar
Actually sounds a lot like a vacuum leak, to corrects earlier issue. Check your intake and vacuum lines.
Old May 21, 2012 | 10:07 PM
Maccoy316's Avatar
No warranty left on the car. I got home and disconnected the battery and connected it again. Started it and still idled funny. Pulled the plugs and checked them. They all seemed fine but cleaned them up anyways. After that I started the car and this time it idled high, Around 1500rpms then eventually kicked itself down. Runs now and took it easy for a few, still idles differently at times. Hard to explain but the SS just isn't the same. Will be looking at her more tomorrow as far as throttle body and fuel pump/lines. Gonna let her rest for the night and get back into it tomorrow.
Old Jan 13, 2014 | 05:17 PM
kobe77's Avatar
mines doing the same thing. ill know if thats my issue when i get my tune from zzp this week
Turbo Johnny
Feb 21, 2019 09:41 AM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
Adam144
Sep 3, 2015 07:48 PM
