Cars In the Shop again
Well my car has been doing a litttle thing of its own for the past wek. Either the radio, gauges, or lights would cut out for a split second. well yesterday the f'in motor cuts out and never starts again. took it to my local chevy dealership, and they cant figure out whats wrong with it. they guy at the desk said its the fuse box? i said how sure are you, he said maybe 25 %. Any one else have his problem. So far i have had nothing but trouble with this balt i hate this car.
almost 2 years with my LT and no problems.. well, major that is.
just a bunch of little things.. like the visor covers breaking off, but that got warrantied.
also on of the belt was fallin apart, warrantied as well.
gl though man, hope you can get it fixed.
right now same problems bro, last saturday car wouldnt start unhooked battery for a bit it started right up ran fine all day, then sunday wouldnt start again this time the battery thing didnt work realized radio would stay on so took out radio fuse. Car started right up .All week so far i have to run the car without the radio fuse, its sucks!!! but at least my car runs if that fuse is in no start take out fuse runs great idk what the problem is im taking out the radio this weekend see if wires are grounding out or if the radio itslef is shot. I hope that all it is but then this morning i was driving to work and my abs light came on all my gauges would drop to zero ( car still ran fine) thn abs light off and gauges back up all in matter of 2-3secs. Did it 3 times in about 1 mile i stopped at a light,turn off back on drove all the way to work another 15 miles no problem. Idk cars effing wierd its got a mind all its own. Gl u still warranty?
This may help
There is a info bulletin on a splice under the driver side seat that can cause all those issues if water (salt water is even worse)gets into it and shorts to ground..
#PIC5073A: Various Electrical Concerns
Condition/Concern:
Some customer may comment on various electrical related issues: SIR light, IP lights flicker / Inop, parking lamps flicker / Inop, tail lamp dim / Inop, trunk open light, radio Inop, door lock Inop, no start, no crank.
One possible area to contribute to this could be the interior wiring at S361 splice. Inspect splice S361, the parking lamp circuit located in the body harness under the drivers seat, for any issues.
Remove the driver's seat from the vehicle. Then remove the driver's door opening carpet retainer. Now peel back the carpet to about the "B" pillar and inspect the wires. If they are damaged, repair splice S361 and other wires, including shrink-wrap to protect against moisture. If there is excessive moisture (pooled up water) then also make sure you water-test the vehicle.
Condition/Concern:
twilson380
09-14-2015 10:52 AM
