catless converte problem.need help!!
i bought a set of vibrant header and downpipe with catless converter. couple days ago the check engine light come on. it says i had a bad catless converter. i just wondering should i just buy a catless converter or the whole down pipe with the catless converter?
thanks the part # is 2536 from vibrant.
um if i read that right you have a catless down pipe thats probably why you threw the code if you are running a catless down pipe you need to tune the code out or just drive around with it on
z28addiction
09-28-2015 12:03 AM
