Cel Codes a plenty today
Old Oct 12, 2009 | 02:45 PM
Ryans09SS's Avatar
My car threw a PO238, PO236, PO098, and a P2199 today, can anyone help me in getting this stuff fixed and what the cause would be before going to the dealer, I just don't want to have to put my stock parts back on to take there so my warranty doesn't get voided with the mods
Old Oct 12, 2009 | 03:48 PM
turbaltss's Avatar
check the recirc fitting on the intake probably popped off. Hahn is turning into quite the 4 letter word! CIA all the way no codes! ever....draw your own conclusions.
Old Oct 12, 2009 | 03:55 PM
elite_Cyborg's Avatar
i got a p0236 but i dont have a turbo
Old Oct 12, 2009 | 05:11 PM
Ryans09SS's Avatar
I figured it might have something to do with the intake the way it was acting and the wierd noises it was making.
Recirc fitting was on fine so I guess that wouldn't be the culprit. Its odd to me cuz yesterday I went to NTB to go ahead get to tires for winter put on, I wonder, even though it was just tires if they might have done something to cause this cuz car was running just fine. It didn't start to act up til this morning.
Old Oct 12, 2009 | 05:20 PM
turbaltss's Avatar
try the old disconnect the battery for 10 minutes to clear the codes and see if they pop up again and I'd check all silicon couplers. Did you up grade to t-bolt clamps or use the worm gear clamps hahn uses? tbolts are worth the extra$ especially since you are tuned.
Old Oct 12, 2009 | 07:06 PM
Ryans09SS's Avatar
I had my friend erase the codes with his scanner twice earlier and they still came back. I have the worm clamps. I need to get t-bolt clamps, I've been dragging my feet on it but need to just do it. I will check all the couplers and mak sure all those are tight down. I'm just trying to get it figured out cuz I'm just worried the dealership will deny me any warranty work since I'm modded.
Old Oct 12, 2009 | 07:32 PM
turbaltss's Avatar
Once you check all the connections do a data log, if possible, and have Vince @trifecta or whoever you ordered your trifecta tune from and let them have a look! one of your codes was a maf sensor error(codes are stickied to the lnf perfomance forum) there has been a few people having bad or blowing there maf sensors!
Old Oct 12, 2009 | 07:35 PM
Ryans09SS's Avatar
I had it scanned earlier to and the maf was functioning, so was the IAT sensor. What ever it is, I have the rpd and where it shows intake air temp and fuel pressure on it, is blank, just a dotted line so that has me thinking its something eleltrical.
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
