Changed Fuel Filter. Car won't start. Need Help!
She runs folks, she runs! Woohoo
I owe JapEatr some beer, or at least rep. I am going to go through this and give all of you rep. The fuse needed to be moved over 2 prongs. I'm the worlds biggest *******. Thank you so much guys i'm good to go.
You are exactly right Doc.
Yep me too , it was 1 row back towards the firewall . After 30 minutes off looking for different stuff we realized this . Atleast i wasn't alone .
hey i used to have this problem lots with deisal trucks try pressureizing the tank by hold a rag over the fuel fill hole and using some
form of pressurized air to charge (hopefully an air line from a compresser or like that)the gas tank while someone is turning the car over
glad i could help, i do this for a living
I also did up an oil change, she's running like a champ.
Thank you sir.
Same Issue
Same exact problem happened for me with the same Solution! I made an account here just so I can post that lol thank you very much for the thread.. I'd still be scratching my head an hour later without it!
Subd for later. I may be having a similar problem.
Throttle body went out, thought it was the fuel filter. I replaced the fuel filter, and the throttle body and I'm having a similar issue.....
Car will initially turn over though, but runs extremely lean and dies after a moment.
Turbo Johnny
Feb 21, 2019 09:41 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
