Check charge system, battery saver
Old Nov 5, 2010 | 03:11 AM
Glowbalt's Avatar
What do these mean when they appear on the DIC. This is really frustrating. I just replaced the alternator and bought a new battery and these still appear but there is no CEL!
Old Nov 5, 2010 | 03:27 AM
outtamymind's Avatar
whats the codes glowbalt?
Old Nov 5, 2010 | 03:31 AM
Glowbalt's Avatar
I'll go check
Old Nov 5, 2010 | 03:32 AM
Baltbitch's Avatar
Residental Bish.
Nice text sayin your home jerk.
and what year are you?
edit.
honey i'm hoooommmeeee hahahaha
Old Nov 5, 2010 | 03:34 AM
Baltbitch's Avatar
Residental Bish.
Hahaha I got that by the green dot saying online!
Old Nov 5, 2010 | 03:36 AM
oh but the green dot lies because my computer is always turned on and facebook and css are always up on the computer. so even when i'm not here i'm still here. eeeerrrriiiieeee hahahaha
Old Nov 5, 2010 | 03:37 AM
come on glowby, cutting into precious movie time here hahaha
Old Nov 5, 2010 | 03:38 AM
Baltbitch's Avatar
Residental Bish.
Hahaha! CSS goes to offline eventually and Facebook gives you a moon! God you think a girl doesn't know how to stalk cyberly? Gooooooshhhhh
Old Nov 5, 2010 | 03:39 AM
oh so now the truth comes out hahaha
Old Nov 5, 2010 | 03:41 AM
Baltbitch's Avatar
Residental Bish.
In the words of a former member " I like to call it closely observing "
a lil too close i think. betty is a jealous girl remember
Old Nov 5, 2010 | 03:44 AM
Baltbitch's Avatar
Residental Bish.
Dude. You need a new car. That's why boys like them. They aren't psycho jealous beaches. They have moments but they do get over it. Sometimes you have to spend money to make them happy but they can get you to point B faster then *******.
Old Nov 5, 2010 | 03:48 AM
i dunno, a good motor boat goes along way
Old Nov 5, 2010 | 03:50 AM
Baltbitch's Avatar
Residental Bish.
Hahahahaha OMG!!! I think you need sleep. God Kay I cant even fight back... You win this round! Hahahaha still laughing yup!!
hahahaha yes i win. please hold while i jump up and down histarically
and glowby your taking way too long. get my number from bish and text me tomorrow, and i'll help ya with your car
Old Nov 5, 2010 | 03:52 AM
Baltbitch's Avatar
Residental Bish.
Hahaha once in 7 months. Wow I mean yay! Haha
Old Nov 5, 2010 | 03:53 AM
i let all those others slide for obvious reasons involving certain clothing items and my car
Old Nov 5, 2010 | 03:57 AM
Baltbitch's Avatar
Residental Bish.
Hahaha! Shush it now bubba
Old Nov 5, 2010 | 04:13 AM
Glowbalt's Avatar
ok post ******! lol. im an 06
Old Nov 5, 2010 | 01:44 PM
Glowbalt's Avatar
Old Nov 5, 2010 | 02:41 PM
Glowbalt's Avatar
Old Nov 5, 2010 | 02:44 PM
redcobalt07's Avatar
remember remember the 5th of november
Old Nov 5, 2010 | 02:46 PM
Glowbalt's Avatar
spam
Old Nov 6, 2010 | 02:26 AM
here ya go glowbie
Instrument Panel Cluster (IPC) Operation
Charge Indicator Operation
The instrument panel cluster (IPC) illuminates the charge indicator in the message center when the one or more of the following occurs:
The engine control module (ECM) detects that the generator output is less than 11 volts or greater than 16 volts . The IPC receives a serial data message from the ECM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts for more than 30 seconds. The IPC receives a serial data message from the body control module (BCM) indicating there is a system voltage range concern.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is ON, with the engine OFF.
Charging System Failure
The BCM and the ECM will send a serial data message to the IPC for the CHARGING SYSTEM FAILURE message to be displayed. It is commanded ON when a charging system DTC is a current DTC. The message is turned OFF when the conditions for clearing the DTC have been met.
Battery Voltage
The IPC displays the system voltage as received from the BCM over the serial data circuit. If there is no communication with the BCM, then the display will read all dashes until communication is restored.
Battery Saver Active
The BATTERY SAVER ACTIVE message will display on the driver information center (DIC) when the vehicle enters a load shed 2 event. Refer to for load shed 2 setting criteria.
and load shed 2 refers to a low voltage battery
