check engine after 30 mins or more driving
Old May 23, 2014 | 10:20 PM
princejwp's Avatar
After driving around 30 mins my check engine light comes on. Took it to auto zone and code read for bad throttle body/position sensor. Changed that out today and still got the check engine after a short drive.
Light goes off after a day or two of very short driving distances. When light is on the only difference in driving is that after 40 mph the car will shift into "passing gear" even if I just barely push the pedal.
Old May 23, 2014 | 10:37 PM
jcobaltss's Avatar
Did you get the code erased after putting the sensor in? Or tried unhooking the battery
Old May 25, 2014 | 11:26 PM
princejwp's Avatar
Yes I unhooked the better for a few minutes and still came on not long after driving.
Old May 31, 2014 | 02:07 AM
princejwp's Avatar
And have also replaced the MAP sensor. To no avail.
Old May 31, 2014 | 03:10 AM
kzak104's Avatar
could be a plug/wire issue, what was the actual code
Old May 31, 2014 | 03:11 AM
Serpent_Servant10's Avatar
Try cleaning the throttle body. If all else fails just replace it.
Old Aug 12, 2014 | 07:25 PM
marc10134's Avatar
What code exactly?
TurboTechRacing
Oct 27, 2015 07:58 AM
Cptnslo
Sep 24, 2015 09:32 AM
dieGone
Sep 23, 2015 10:20 AM
Fearedbynone
Sep 4, 2015 10:24 AM
