Clutch pressure problem
So I had my master & slave cylinder replaced about a month ago & I'm still having problems. After the car sits for a few hours, the clutch feels normal but then after I drive around for a bit, the pressure slowly goes away & it gets harder to go into gear. What could the problem be? Could it just be some air in the lines still? Thanks in advance!
Most likely need to bleed the lines. Do it right, get a bleeder kit so u can do it urself, then u just hook it to the clutch and if its like mine, u use a compressed and it creates vacuum and sucks the fluid through the line, do it till there is no more air bubbles in ur kit line. Make sure u keep resivour filled
I was having the same issue, eventually i went to put it in Reverse and i pushed the clutch to the floor and it stayed there, turned out my TOB was torn and was leaking fluid.
