clutchmasters stage 2 problems??????
Old Jun 16, 2007 | 05:03 PM
mastoer's Avatar
hey guys jus got the clutchmasters stage 2 clucth put in and now i dont hit full boost anymore.....it only get 5-7psi and it kind of stutters im not sure its the clutch or not but everything was ruuning fine when i dropped it off........the clutch is smooth and engages real nice but it doesnt hit full boost.....and also is the clutch adjustable???? thanks guys for the help
Old Jun 16, 2007 | 05:05 PM
06blackg85ss's Avatar
something wasn't put back together correctly, clutch has nothing to do with boost, unless it's slipping (which it would if it's new and you didn't do the break in on it) .. but the clutchmasters clutches don't work properly on our cars anyway. Also are clutch setup is self adjusting
Old Jun 16, 2007 | 05:26 PM
mastoer's Avatar
imma have them go back and check the set up again and see wassup ....but im not sure what goin on
Old Jun 16, 2007 | 07:43 PM
shaunmcdee's Avatar
i would probably start by spraying your vaccum lines and see if theres soemthing that they mightve tore, or is dissconnected.
spray some throttle body cleaner on all your vac lines while the car is running, if the idle changes at all, then its for sure a vac leak.
Very common mistake, wouldnt be surprised if thats the issue.
Old Jun 28, 2007 | 11:09 PM
mastoer's Avatar
problem solved .......^^^^
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
