The Cobalt DTC thread (merged)
Old 01-24-2008, 08:48 PM
freeloader_20's Avatar
Originally Posted by Tyler Rinehart
On Saturday I was coming back on the interstate and all of a sudden my check engine light came on, i had noticed that my car was running a little sluggish a when i first started....i took it to the dealer b/c it is still under waranty and they said I need a new fuel injectore....odd if you ask me, the car is only and 06.
that's the same issue my car had. I tried to ignore the c/e light but, the car was wasting to much freaking gas for a 4 banger. not even my tahoe v8 wastes so much gas. Took it to the dealer, and they tried to pin it on me for "lack of maintenance" I told them I just bought the damn car about 5 mths ago w/ the 3/36 remaining. They checked their system and sure enough, I was right. Finally, they replaced the injectors.
Old 01-26-2008, 06:52 PM
RedEcotecSS's Avatar
Modified Exhaust now CEL's - P0030, P0036, P0102, P0443 - Solution Inside
So i traded my GM performance exhaust for a friend's DC sports exhaust just for the hell of it. i dont regret trading, although i had some problems...
first, the bolts wouldnt screw in right so i had a hell of an exhaust leak (took it to the muffler shop and they fixed it) .. then my buddy put the o2 in wrong and the wires were pressed up against the heat shield. the mechanic at the shop told me the wires on the o2 had been split causing me to throw 4 cel's... so i left.. driving on down the road the car begins to run like complete **** (had been doing this since i first put on the DC Sports) .. would deleting the rear o2 make me run correctly again?? tomorrow i was supposed to get my rear o2 deleted anyway for the p0420 code so i can pass inspection. do you think by me deleting the rear o2 these codes and problems will go away?? Thanks!!!
codes are as follows...
P0030 HO2S Heater Control Circuit Sensor 1 ECM, PCM
P0036 HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency ECM, PCM
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit ECM, PCM
P.S. tried to remove them with my interceptor and they just keep coming back...
Old 01-27-2008, 05:53 PM
RaineMan's Avatar
*shakes head*
why oh why do you get yourself into these things my friend?
you know there's a whole crew of us right down here in Charlotte with HPTuners that will be glad to fix you up.
Old 01-27-2008, 05:57 PM
OneSlowGto's Avatar
If your missing the rear 02's the car should still run fine. There is something else going on.
Old 01-27-2008, 06:02 PM
an0malous's Avatar
^^ yup
rear O2 only checks your cats efficiency.
something else is definately going on.
Old 01-27-2008, 06:05 PM
Forced SS's Avatar
I had the same thing happen to me when I put my hahn cat back on. Check your ems fuse under the hood(10amp).If it's poped you have a straight to ground short on youf o2 sensor. Look for bare wire then tape it up.My would do it when I made a right hand turn and the exaust would swing left an touch the heat shield and pop a fuse. Good luck
Old 01-27-2008, 08:01 PM
Sunburst_SS's Avatar
problem fixed, your welcome
Originally Posted by RaineMan
*shakes head*
unfortunatley HPT won't fix a wire shorted to ground
Old 01-27-2008, 08:04 PM
Exactly what was wrong. Thanks man.
Huge thanks to Sunburst_SS for pin pointing the problem!
Old 01-27-2008, 08:08 PM
no prob. dude.....that's what GM pays me the big bucks for lol
Old 01-27-2008, 08:14 PM
Original Hayden Fanatic
REIGN SS's Avatar
!!!I LOVE YOU ALL!!!
Ive been throwing those codes for 2 months without a solution, i was ready to buy new o2 sensors because of it!!
I've searched and never read this sollution!!
Old 01-27-2008, 08:17 PM
  #36
if you have a manual transmission....there was a bullitin for wires rubbing on the clutch pedal assembly, and by the oil filter housing. It'll cause an intermittent code, might want to check that out
Old 01-27-2008, 08:19 PM
  #37
REIGN SS's Avatar
would that be a P0833
Old 01-27-2008, 08:25 PM
  #38
here's what SI says about the blown/loose emissions fuse.......just something to check if you're having those codes thrown
There are 2 main areas to look at for the cause of this blown/loose fuse.
Check circuit 5291 for a short to ground (STG) at the clutch pedal position switch connector as it might get shorted to the clutch bracket. If connector looks ok, then inspect the 10 amp emissions fuse in the Underhood Electrical Center to ensure it is properly seated.
Note: This clutch position switch connector is there even on automatic vehicles.
Check for a short To ground (STG) at the oil filter adapter housing.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
basically a p0833 will set when the ECM senses a certain number of gear changes without
detecting a clutch switch movement.
Old 01-27-2008, 08:28 PM
  #39
REIGN SS's Avatar
Nice, I stickied this, I think the issue might be the design of the older ZZP midlengths putting the o2 sensor to close the the wall, and when the engine shifts during driving it can cause it to rub. As I have/had the same issue going to a shop and having the o2 sensor rub as the OP mentioned.
  #40
good, glad I could help
Old 01-27-2008, 08:29 PM
  #41
Did you change your fuse in your fuse panel under your hood? It's like the EXH fuse.
  #42
REIGN SS's Avatar
Yes i did, there is a spare 10 in the box.... Then i cleared the codes with my DashHawk, and they didn't come back
Old 01-27-2008, 08:30 PM
  #43
Yes sir. Same thing I did. Now my car runs normal again, no spuddering or anything.
Old 01-29-2008, 03:08 PM
  #44
Forced SS's Avatar
Glad I could help.
Old 01-30-2008, 12:40 PM
  #45
RaineMan's Avatar
so all that for a 25 cent fuse?
damn... go figure...
good save Sunburst...
Old 02-05-2008, 10:54 PM
  #46
South Central *********
JapEatr's Avatar
i have the PO133 and PO135
EMISS fuse never been popped but replaced anyway
replace O2 sensor 1 with an OE replacement bosch sensor
Ran thru the diag procedures for both codes with no luck
no rubbing can be seen
any thoughts
Old 02-05-2008, 11:24 PM
  #47
any thoughts
Check for a short To ground at the oil filter adapter housing.
maybe you're getting an intermittent short on the circuit.....check that out
Old 02-06-2008, 11:44 PM
  #48
JapEatr's Avatar
checked for shorts for ground and checked the clutch harnesses
rerouted and secure all the connectors and harnesses by the oil filter with zip ties
any other thoughts?
Have never popped the emiss fuse but on my scanner it show the O2S1 heater dropin for 0.6A to zero amps intermittantly
Old 02-07-2008, 11:56 AM
  #49
any other thoughts?
you measure resistance on the circuit?? make sure the wire is actually good.....
Old 02-07-2008, 12:17 PM
  #50
blu3_v1p3r's Avatar
I had the P0833... Clutch Position Switch... All i did was erase the code with an OBD2 scanner and it never came back up, i just figured it was a fluke
Quick Reply: The Cobalt DTC thread (merged)
