Cobalt/G5 master DTC list
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable DTCs in alphanumeric order with descriptors.
The GMLAN modules on this vehicle also support DTC Symptom descriptors.
DTC
DTC Descriptor
Module That Sets the DTC
Diagnostic Procedure
B0012
Driver Frontal Deployment Loop Stage 1
SDM
DTC B0012 or B0013
P0013
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit
ECM
DTC P0010, P0013, or P2088-P2091 for the 2.0L engine
or
DTC P0010 or P0013 for the 2.2L or 2.4L engine
P0014
Exhaust Camshaft Position (CMP) System Performance
ECM
DTC P0011 or P0014 for the 2.0L engine
or
DTC P0011 or P0014 for the 2.2L or 2.4L engine
P0016
Crankshaft Position (CKP) - Camshaft Position (CMP) Correlation
ECM
DTC P0016 or P0017 for the 2.0L engine
or
DTC P0016 or P0017 for the 2.2L or 2.4L engine
P0017
Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation
ECM
or
P0030
HO2S Heater Control Circuit Sensor 1
ECM
DTC P0030, P0031, P0032, P0053, or P0135 for the 2.0L engine
or
DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.2L or 2.4L engine
P0031
HO2S Heater Control Circuit Low Voltage Sensor 1
ECM
P0032
HO2S Heater Control Circuit High Voltage Sensor 1
ECM
P0033
Turbocharger Bypass Valve Solenoid Control Circuit
ECM
DTC P0033, P0034, or P0035
P0034
Turbocharger Bypass Valve Solenoid Control Circuit Low Voltage
ECM
P0035
Turbocharger Bypass Valve Solenoid Control Circuit High Voltage
ECM
P0036
HO2S Heater Control Circuit Sensor 2
ECM
DTC P0036, P0037, P0038, or P0141 for the 2.0L engine
or
P0037
HO2S Heater Control Circuit Low Voltage Sensor 2
ECM
P0038
HO2S Heater Control Circuit High Voltage Sensor 2
ECM
P0053
HO2S Heater Resistance Sensor 1
ECM
B0013
Driver Frontal Deployment Loop Stage 2
SDM
DTC B0012 or B0013
B0015
Left Front Pretensioner Deployment Loop
SDM
DTC B0014-B0045
B0016
Left Roof Rail Deployment Loop Stage 1
SDM
DTC B0014-B0045
B0019
Passenger Frontal Deployment Loop Stage 1
SDM
DTC B0014-B0045
B0020
Passenger Frontal Deployment Loop Stage 2
SDM
DTC B0014-B0045
B0022
Right Front Pretensioner Deployment Loop
SDM
DTC B0014-B0045
B0023
Right Roof Rail Deployment Loop Stage 1
SDM
DTC B0014-B0045
B0052
Deployment Commanded
SDM
DTC B0052 or B0053
B0053
Deployment Commanded with Loop DTCs Present
SDM
DTC B0052 or B0053
B0081
Passenger Presence System
SDM
DTC B0081
B0083
Front End Sensor 1
SDM
DTC B0083-B0088
B0085
Left Front Side Impact Sensor
SDM
DTC B0083-B0088
B0086
Right Front Side Impact Sensor
SDM
DTC B0083-B0088
B0158
Outside Air Temperature Sensor Circuit
BCM
DTC B0158
or
DTC B0158
B0283
Electric Rear Defrost Circuit
BCM
DTC B0283
B0685
Security System Indicator Circuit Short to Battery
BCM, IPC
DTC B0685
B1000
Electronic Control Unit (ECU) Performance
BCM, DRR, IPC, Radio, RCDLR, SDM, TDM, VCIM
DTC B1000
B1001
Option Configuration Error
BCM, DRR, Radio, VCIM
DTC B1001
ROS, SDM
DTC B1001
B1004
Keep Alive Memory (KAM) Reset
BCM
DTC B1004
B1009
EEPROM Checksum Mismatch
BCM
DTC B1009
B1011
System Disabled Information Stored
SDM
DTC B1011
B1019
System Configuration Error
SDM
DTC B1019
B101D
Internal Fault
PPS
DTC B101D
B101E
ECU Error
PPS
DTC B101E
B1025
Left Front Audio Output Circuit
Radio
DTC B1025, B1035, B1045, or B1055
B1035
Right Front Audio Output Circuit
Radio
B1045
Left Rear Audio Output Circuit
Radio
B1055
Right Rear Audio Output Circuit
Radio
B1259
Antenna Ground Circuit
DRR
DTC B1259
B1287
External Amp Control
Radio
DTC B1287
B1325
Device Power 1 Circuit
BCM, IPC, Radio, SDM
DTC B1325
B1370
Device Ignition 1 Circuit
BCM
DTC B1370-B1379, B1380-B1389, or B1440-B1443
SDM
DTC B1370
B1380
Device Ignition ACCESSORY Circuit
BCM
B1424
Device Voltage Low
TDM
DTC B1424
B1441
Device Ignition OFF, RUN and CRANK Circuit
BCM
B1480
Battery Rundown Protection Circuit
BCM
DTC B1480
B1516
Battery Current Sensor Performance Signal Invalid
BCM
DTC B1516
B1517
Battery 1 Voltage
BCM
DTC B1517
B2455
Cellular Phone Microphone Circuit Malfunction
VCIM
DTC B2455
B2462
Global Positioning System (GPS) Antenna Malfunction
VCIM
DTC B2462
B2470
Cellular Phone Antenna Circuit Malfunction
VCIM
DTC B2470
B2476
Cellular Phone Select Service Switch Malfunction
VCIM
DTC B2476 or B2482
B2482
Cellular Phone Select Switch Range/Performance
VCIM
DTC B2476 or B2482
B2483
GPS Sensor Circuit Low
VCIM
DTC B2483 or B2484
B2484
GPS Sensor Circuit Open
VCIM
DTC B2483 or B2484
B2485
Wireless Communication Antenna Circuit (Bluetooth)
VCIM
DTC B2485
B2530
Front Fog Lamps Control Circuit
BCM
DTC B2530
B2555
Passenger Compartment Lamp Control Circuit
BCM
DTC B2555
B2580
Headlamp High Beam Control Circuit
BCM
DTC B2580
B2625
Display Dimming Pulse Width Modulation (PWM) Output Circuit
BCM
DTC B2625
B2645
Ambient Light Sensor Circuit
BCM
DTC B2645
B2705
Gearshift Unlock Circuit
BCM
DTC B2705
B2750
Horn Relay Output
BCM
DTC B2750
B2961
Key In Ignition Circuit
BCM
DTC B2961
B3006
Hood Ajar Circuit
BCM
DTC B3006
B3031
Security System Controller In Learn Mode
BCM
DTC B3031
B3055
No Transponder Modulation or No Transponder
TDM
DTC B3055
B3060
Unprogrammed Transponder Identification Code Received
VTD
DTC B3060
B3105
Keyless Entry System Key Fobs Not Programmed
RCDLR
DTC B3105
B3109
Keyless Transmitter Low Battery
RCDLR
DTC B3109, B3110, B3111, or B3112
B3110
Keyless Entry Transmitter 2 Low Battery
RCDLR
B3111
Keyless Entry Transmitter 3 Low Battery
RCDLR
B3112
Keyless Entry Transmitter 4 Battery
RCDLR
B3265
Trunk Relay Output
BCM
DTC B3265
B3715
Front Wiper Relay Drive Circuit
BCM
DTC B3715
B3794
Cruise Control Function Request Circuit
BCM
DTC B3794
B3903
Stop Lamp Relay Circuit
BCM
DTC B3903
B3935
Transponder Authentication Error
TDM
DTC B3935
B3948
Left Front Turn Signal Circuit
BCM
DTC B3948 or B3949
B3949
Right Front Turn Signal Circuit
BCM
DTC B3948 or B3949
B3950
Left Rear Turn Signal Circuit
BCM
DTC B3950 or B3951
B3951
Right Rear Turn Signal Circuit
BCM
DTC B3950 or B3951
B3976
Unconfigured Transponder
TDM
DTC B3976
C0000
Vehicle Speed Information Circuit
PSCM
DTC C0000
C0035
Left Front Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0040
Right Front Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0045
Left Rear Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0050
Right Rear Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0110
Pump Motor Circuit
EBCM
DTC C0110
C0131
ABS Pressure Circuit
EBCM
DTC C0131
C0161
ABS/TCS Brake Switch Circuit Signal Malfunction
EBCM
DTC C0161
C0176
System Thermal Error
PSCM
DTC C0176
C0186
Lateral Accelerometer Circuit
EBCM
DTC C0186
C0196
Yaw Rate Circuit
EBCM
DTC C0196
C0201
Antilock Brake System (ABS) Enable Relay Contact Circuit
EBCM
DTC C0201
C0252
VSES Sensor Uncorrelated
EBCM
DTC C0252
C0267
Low Brake Fluid Indicated
EBCM
DTC C0267
C0277
Brake Pedal Position Sensor Circuit
BCM
DTC C0277
C0278
Brake Pedal Position Sensor Not Calibrated
BCM
DTC C0278
C0280
Stability System Active Too Long
EBCM
DTC C0280
C0292
VSES Combination Sensor Circuits
EBCM
DTC C0292
C0299
Brake Booster Performance
EBCM
DTC C0299
C0460
Steering Position Signal
EBCM
DTC C0460
C0475
Electric Steering Motor Circuit
PSCM
DTC C0475
C0545
Steering Wheel Torque Input Sensor
PSCM
DTC C0545
C0550
EBCM, EPS, PSCM
DTC C0550
C0551
EBCM
DTC C0551
C0561
EBCM
DTC C0561
C0569
EBCM
DTC C0569
RCDLR
DTC C0569
C0750
Left Front Low Tire Pressure Sensor
RCDLR
DTC C0750, C0755, C0760, or C0765
C0755
Right Front Low Tire Pressure Sensor
RCDLR
C0760
Left Rear Low Tire Pressure Sensor
RCDLR
C0765
Right Rear Low Tire Pressure Sensor
RCDLR
C0775
Low Tire Pressure System Sensors Not Learned
RCDLR
DTC C0775
C0845
PSCM
DTC C0845
C0870
Device Voltage Reference Output 1 Circuit
BCM
DTC C0870
C0895
Device Voltage Threshold
PSCM
DTC C0895
C0899
Device Voltage Low
EBCM
DTC C0899
C0900
Device Voltage High
EBCM
DTC C0900
C1100
Brake Booster Vacuum Sensor Performance
EBCM
DTC C1100
P0010
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
ECM
or
P0011
Intake Camshaft Position (CMP) System Performance
ECM
or
P0013
ECM
or
P0014
ECM
or
P0016
ECM
or
P0017
ECM
or
P0030
ECM
or
P0031
ECM
P0032
ECM
P0033
ECM
P0034
ECM
P0035
ECM
P0036
ECM
or
P0037
ECM
P0038
ECM
P0053
ECM
or
P0054
HO2S Heater Resistance Sensor 2
ECM
P0068
Throttle Body Airflow Performance
ECM
DTC P0068 or P0121
P0087
Fuel Rail Pressure (FRP) Too Low
ECM
DTC P0087, P0088, or P0089
P0088
Fuel Rail Pressure (FRP) Too High
ECM
P0089
Fuel Pressure Regulator Performance
ECM
P0090
Fuel Pressure Regulator Control Circuit
ECM
DTC P0090, P0091, or P0092
P0091
Fuel Pressure Regulator Solenoid 1 Control Circuit Low Voltage
ECM
P0092
Fuel Pressure Regulator Solenoid 1 Control Circuit High Voltage
ECM
P0096
Intake Air Temperature (IAT) Sensor 2 Performance
ECM
DTC P0096, P0097, P0098, or P0099
P0097
Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
ECM
P0098
Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage
ECM
P0099
Intake Air Temperature (IAT) Sensor 2 Circuit Intermittent
ECM
P0100
Mass Air Flow (MAF) Sensor Circuit
ECM
DTC P0100, P0102, or P0103
P0101
Mass Air Flow (MAF) Sensor Performance
ECM
DTC P0101 for the 2.0L engine
or
DTC P0101 or P1101 for the 2.2L or 2.4L engine
P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
ECM
DTC P0100, P0102, or P0103 for the 2.0L engine
or
DTC P0102 or P0103 for the 2.2L or 2.4L engine
P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
ECM
or
P0106
Manifold Absolute Pressure (MAP) Sensor Performance
ECM
DTC P0106 for the 2.0L engine
or
DTC P0106 for the 2.2L or 2.4L engine
P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
ECM
DTC P0107 or P0108 for the 2.0L engine
or
DTC P0107 or P0108 for the 2.2L or 2.4L engine
P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
ECM
or
P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
ECM
DTC P0112, P0113, or P0114 for the 2.0L engine
or
DTC P0112 or P0113 for the 2.2L or 2.4L engine
P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
ECM
or
P0114
Intake Air Temperature (IAT) Sensor Circuit Intermittent
ECM
P0116
Engine Coolant Temperature (ECT) Sensor Performance
ECM
DTC P0116 for the 2.0L engine
or
DTC P0116 for the 2.2L or 2.4L engine
P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
ECM
DTC P0117, P0118, or P0119 for the 2.0L engine
or
DTC P0117 or P0118 for the 2.2L or 2.4L engine
P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
ECM
or
P0119
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent
ECM
P0120
Throttle Position (TP) Sensor Circuit
ECM
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135
P0121
Throttle Position (TP) Sensor 1 Performance
ECM
DTC P0121, P0122, or P0123
P0122
Throttle Position (TP) Sensor 1 Circuit Low Voltage
ECM
DTC P0121, P0122, or P0123 for the 2.0L engine
or
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.2L or 2.4L engine
P0123
Throttle Position (TP) Sensor 1 Circuit High Voltage
ECM
or
P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
ECM
DTC P0128 for the 2.0L engine
or
DTC P0128 for the 2.2L or 2.4L engine
P0130
HO2S Circuit Closed Loop (CL) Performance Sensor 1
ECM
DTC P0130-P0133, P2195, P2196, or P2297
P0131
HO2S Circuit Low Voltage Sensor 1
ECM
DTC P0130-P0133, P2195, P2196, or P2297 for the 2.0L engine
or
DTC P0131, P0132, P0137, or P0138 for the 2.2L or 2.4L engine
P0132
HO2S Circuit High Voltage Sensor 1
ECM
or
P0133
HO2S Slow Response Sensor 1
ECM
or
DTC P0133, P0134, P013A, P013B, P013E, P013F, P0140, P1133, P2270, P2271, or P2A00 for the 2.2L or 2.4L engine
P0134
HO2S Circuit Insufficient Activity Sensor 1
ECM
P0135
HO2S Heater Performance Sensor 1
ECM
or
P0137
HO2S Circuit Low Voltage Sensor 2
ECM
DTC P0137, P0138, P013A, P013E, P0140, P2232, P2270, or P2271 for the 2.0L engine
or
P0138
HO2S Circuit High Voltage Sensor 2
ECM
or
P013A
HO2S Slow Response Rich to Lean Sensor 2
ECM
or
P013B
HO2S Slow Response Lean to Rich Sensor 2
ECM
P013E
HO2S Delayed Response Rich to Lean Sensor 2
ECM
or
P013F
HO2S Delayed Response Lean to Rich Sensor 2
ECM
P0140
HO2S Circuit Insufficient Activity Sensor 2
ECM
or
P0141
HO2S Heater Performance Sensor 2
ECM
or
P0171
Fuel Trim System Lean
ECM
DTC P0171 or P0172
P0172
Fuel Trim System Rich
ECM
DTC P0171 or P0172
P0191
Fuel Rail Pressure (FRP) Sensor Performance
ECM
DTC P0191, P0192, or P0193
P0192
Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
ECM
P0193
Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
ECM
P0201
Injector 1 Control Circuit
ECM
DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270, P0271, P2146, P2149, P2152, or P2155 for the 2.0L engine
or
DTC P0201, P0202, P0203, or P0204 for the 2.2L or 2.4L engine
P0202
Injector 2 Control Circuit
ECM
or
P0203
Injector 3 Control Circuit
ECM
or
P0204
Injector 4 Control Circuit
ECM
or
P0218
Transmission Fluid Overtemperature
TCM
DTC P0218
P0220
Throttle Position (TP) Sensor 2 Circuit
ECM
P0221
Throttle Position (TP) Sensor 2 Performance
ECM
DTC P0221, P0222, or P0223
P0222
Throttle Position (TP) Sensor 2 Circuit Low Voltage
ECM
DTC P0221, P0222, or P0223 for the 2.0L engine
or
P0223
Throttle Position (TP) Sensor 2 Circuit High Voltage
ECM
or
P0230
Fuel Pump Relay Control Circuit
ECM
DTC P0230
P0234
Turbocharger Engine Overboost
ECM
DTC P0234 or P0299
P0236
Turbocharger Boost System Performance
ECM
DTC P0236, P0237, or P0238
P0237
Turbocharger Boost Sensor Circuit Low Voltage
ECM
P0238
Turbocharger Boost Sensor Circuit High Voltage
ECM
P0243
Turbocharger Wastegate Solenoid Control Circuit
ECM
DTC P0243, P0245, or P0246
P0245
Turbocharger Wastegate Solenoid Control Circuit Low Voltage
ECM
P0246
Turbocharger Wastegate Solenoid Control Circuit High Voltage
ECM
P0261
Injector 1 Control Circuit Low Voltage
ECM
P0262
Injector 1 Control Circuit High Voltage
ECM
P0264
Injector 2 Control Circuit Low Voltage
ECM
P0265
Injector 2 Control Circuit High Voltage
ECM
P0267
Injector 3 Control Circuit Low Voltage
ECM
P0268
Injector 3 Control Circuit High Voltage
ECM
P0270
Injector 4 Control Circuit Low Voltage
ECM
P0271
Injector 4 Control Circuit High Voltage
ECM
P0299
Turbocharger Engine Underboost
ECM
DTC P0234 or P0299
P029D
Injector 1 Leak
ECM
DTC P029D, P02A1, P02A5, or P02A9
P02A1
Injector 2 Leak
ECM
P02A5
Injector 3 Leak
ECM
P02A9
Injector 4 Leak
ECM
P0300
Engine Misfire Detected
ECM
DTC P0300-P0304 for the 2.0L engine
or
DTC P0300-P0304 for the 2.2L or 2.4L engine
P0301
Cylinder 1 Misfire Detected
ECM
or
P0302
Cylinder 2 Misfire Detected
ECM
or
P0303
Cylinder 3 Misfire Detected
ECM
or
P0304
Cylinder 4 Misfire Detected
ECM
or
P0315
Crankshaft Position (CKP) System Variation Not Learned
ECM
DTC P0315
P0324
Knock Sensor (KS) Performance
ECM
DTC P0324, P0326, P0327, P0328, P0331, P0332, or P0333
P0325
Knock Sensor (KS) Circuit
ECM
DTC P0325, P0326, P0327, or P0328
P0326
Knock Sensor (KS) 1 Performance
ECM
DTC P0324, P0326, P0327, P0328, P0331, P0332, or P0333 for the 2.0L engine
DTC P0325, P0326, P0327, or P0328 for the 2.2L or 2.4L engine
P0327
Knock Sensor (KS) 1 Circuit Low Voltage
ECM
Knock Sensor (KS) Circuit Low Voltage
P0328
Knock Sensor (KS) 1 Circuit High Voltage
ECM
Knock Sensor (KS) Circuit High Voltage
P0331
Knock Sensor (KS) 2 Performance
ECM
P0332
Knock Sensor (KS) 2 Circuit Low Voltage
ECM
P0333
Knock Sensor (KS) 2 Circuit High Voltage
ECM
P0335
Crankshaft Position (CKP) Sensor Circuit
ECM
or
DTC P0335 or P0336 for the 2.2L or 2.4L engine
P0336
Crankshaft Position (CKP) Sensor Performance
ECM
or
P0338
Crankshaft Position (CKP) Sensor Circuit High Duty Cycle
ECM
P0340
Intake Camshaft Position (CMP) Sensor Circuit
ECM
DTC P0340 or P0365
P0341
Intake Camshaft Position (CMP) Sensor Performance
ECM
DTC P0341, P0342, or P0343 for the 2.0L engine
or
DTC P0341 or P0366 for the 2.2L or 2.4L engine
P0342
Intake Camshaft Position (CMP) Sensor Circuit Low Voltage
ECM
P0343
Intake Camshaft Position (CMP) Sensor Circuit High Voltage
ECM
P0351
Ignition Coil 1 Control Circuit
ECM
DTC P0351-P0354 for the 2.0L engine
or
DTC P0351-P0354 for the 2.2L (L61) engine
P0352
Ignition Coil 2 Control Circuit
ECM
or
P0353
Ignition Coil 3 Control Circuit
ECM
or
P0354
Ignition Coil 4 Control Circuit
ECM
or
P0365
Exhaust Camshaft Position (CMP) Sensor Circuit
ECM
DTC P0340 or P0365
P0366
Exhaust Camshaft Position (CMP) Sensor Performance
ECM
DTC P0366, P0367, or P0368 for the 2.0L engine
or
P0367
Exhaust Camshaft Position (CMP) Sensor Circuit Low Voltage
ECM
P0368
Exhaust Camshaft Position (CMP) Sensor Circuit High Voltage
ECM
P0411
Secondary Air Injection (AIR) System Incorrect Air Flow Detected
ECM
DTC P0411, P0412, P0418, P2440, or P2444
P0412
Secondary Air Injection (AIR) Solenoid Control Circuit
ECM
P0418
Secondary Air Injection (AIR) Pump Control Circuit
ECM
P0420
Catalyst System Low Efficiency
ECM
DTC P0420 for the 2.0L engine
or
DTC P0420 for the 2.2L or 2.4L engine
P0442
Evaporative Emissions (EVAP) System Small Leak Detected
ECM
DTC P0442 for the 2.0L engine
or
DTC P0442 for the 2.2L or 2.4L engine
P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
ECM
DTC P0443, P0449, P0458, P0459, P0498, or P0499 for the 2.0L engine
or
DTC P0443 or P0449 for the 2.2L or 2.4L engine
P0446
Evaporative Emissions (EVAP) Vent System Performance
ECM
DTC P0446 for the 2.0L engine
or
DTC P0446 for the 2.2L or 2.4L engine
P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
ECM
or
P0450
Fuel Tank Pressure (FTP) Sensor Circuit
ECM
DTC P0450-P0453
P0451
Fuel Tank Pressure (FTP) Sensor Performance
ECM
DTC P0450-P0453 for the 2.0L engine
or
DTC P0451, P0452, P0453, or P0454 for the 2.2L or 2.4L engine
P0452
Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
ECM
or
P0453
Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
ECM
or
P0454
Fuel Tank Pressure (FTP) Sensor Circuit Intermittent
ECM
P0455
Evaporative Emission (EVAP) System Large Leak
ECM
DTC P0455 for the 2.0L engine
or
DTC P0455 for the 2.2L or 2.4L engine
P0458
Evaporative Emission (EVAP) Purge Solenoid Control Circuit Low Voltage
ECM
P0459
Evaporative Emission (EVAP) Purge Solenoid Control Circuit High Voltage
ECM
P0461
Fuel Level Sensor Circuit Performance
ECM
DTC P0461
P0462
Fuel Level Sensor Circuit Low Voltage
ECM
DTC P0462
P0463
Fuel Level Sensor Circuit High Voltage
ECM
DTC P0463
P0464
Fuel Level Sensor 1 Circuit Intermittent
ECM
DTC P0464
P0480
Cooling Fan Relay 1 Control Circuit
ECM
DTC P0480, P0481, P0691, P0692, P0693, or P0694 for the 2.0L engine
or
DTC P0480 or P0481 for the 2.2L or 2.4L engine
P0481
Cooling Fan Relay 2 and 3 Control Circuit
ECM
Cooling Fan Relay 2 Control Circuit
P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
ECM
DTC P0496 for the 2.0L engine
or
DTC P0496 for the 2.2L or 2.4L engine
P0497
Evaporative Emission System Low Purge Flow
ECM
DTC P0497
P0498
Evaporative Emission (EVAP) Vent Solenoid Control Circuit Low Voltage
ECM
P0499
Evaporative Emission (EVAP) Vent Solenoid Control Circuit High Voltage
ECM
P0501
Vehicle Speed Sensor (VSS) Performance
ECM
DTC P0501
P0502
Vehicle Speed Sensor (VSS) Circuit Low Voltage
ECM
DTC P0502 or P0503 for the Getrag 5 Speed
or
DTC P0502 or P0503 (MU3)
P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
ECM
or
P0506
Idle Speed Low
ECM
DTC P0506 or P0507 for the 2.0L engine
or
DTC P0506 or P0507 for the 2.2L or 2.4L engine
P0507
Idle Speed High
ECM
or
P050A
Cold Start Idle Air Control System Performance
ECM
DTC P050A
P0520
Engine Oil Pressure (EOP) Sensor Circuit
ECM
DTC P0520
P0532
Air Conditioning Pressure Sensor Circuit Low Voltage
ECM
DTC P0532 or P0533
P0533
Air Conditioning Pressure Sensor Circuit High Voltage
ECM
DTC P0532 or P0533
P0562
System Voltage Low
ECM
DTC P0562
TCM
DTC P0562 or P0563
P0563
System Voltage High
ECM
DTC P0563
TCM
DTC P0562 or P0563
P0571
Cruise Control Brake Switch Circuit
ECM
DTC P0571
P0572
Brake Switch Circuit 1 Low Voltage
ECM
DTC P0572 or P0573
P0573
Brake Switch Circuit 1 High Voltage
ECM
DTC P0572 or P0573
P0575
Cruise Control Switch Signal Circuit
ECM
DTC P0575
P0601
Control Module Read Only Memory (ROM)
ECM
DTC P0601-P0606, P064D, P167A, P167D, P2105, or P2610 for the 2.0L engine
or
DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.2L or 2.4L engine
Transmission Control Module (TCM) Read Only Memory (ROM)
TCM
DTC P0601-P0604 or P062F
P0602
Control Module Not Programmed
ECM
or
Transmission Control Module (TCM) Not Programmed
TCM
P0603
Control Module Long Term Memory Reset
ECM
or
Transmission Control Module (TCM) Long Term Memory Reset
TCM
P0604
Control Module Random Access Memory (RAM)
ECM
or
Transmission Control Module (TCM) Random Access Memory (RAM)
TCM
P0606
Control Module Internal Performance
ECM
or
P0607
Control Module Performance
ECM
P060D
Control Module Accelerator Pedal Position (APP) System Performance
ECM
P0615
Starter Relay Control Circuit
ECM
DTC P0615
P0616
Starter Relay Control Circuit Low Voltage
ECM
DTC P0616
P0617
Starter Relay Control Circuit High Voltage
ECM
DTC P0617
P0621
Generator L-Terminal Circuit
ECM
DTC P0621
P0622
Generator F-Terminal Circuit
ECM
DTC P0622
P0627
ECM
DTC P0627, P0628, or P0629
P0628
Fuel Pump Relay Control Circuit Low Voltage
ECM
P0629
Fuel Pump Relay Control Circuit High Voltage
ECM
P062B
Control Module Fuel Injector Control Performance
ECM
P062F
Control Module Long Term Memory Performance
ECM
Transmission Control Module (TCM) Long Term Memory Performance
TCM
DTC P0601-P0604 or P062F for the 4T45-E engine
P0638
Throttle Actuator Control (TAC) Command Performance
ECM
DTC P0638, P1551, P2100, P2101, P2119, or P2176
P0641
5-Volt Reference 1 Circuit
ECM
DTC P0641-P0643, P0651-P0653, or P0697-P0699 for the 2.0L engine
or
DTC P0641 or P0651 for the 2.2L or 2.4L engine
P0642
5-Volt Reference 1 Low Voltage
ECM
P0643
5-Volt Reference 1 High Voltage
ECM
P0645
Air Conditioning Clutch Relay Control Circuit
ECM
DTC P0645
P064D
Control Module HO2S 1 System Performance
ECM
P0650
Malfunction Indicator Lamp (MIL) Control Circuit
ECM
DTC P0650 for the 2.0L engine
or
DTC P0650 for the 2.2L or 2.4L engine
P0651
5-Volt Reference 2 Circuit
ECM
or
P0652
5-Volt Reference 2 Low Voltage
ECM
P0653
5-Volt Reference 2 High Voltage
ECM
P0685
Engine Controls Ignition Relay Control Circuit
ECM
DTC P0685, P0686, P0687, P0689, or P0690 for the 2.0L engine
or
DTC P0685 or P0690 for the 2.2L or 2.4L engine
P0686
Engine Controls Ignition Relay Control Circuit Low Voltage
ECM
P0687
Engine Controls Ignition Relay Control Circuit High Voltage
ECM
P0689
Engine Controls Ignition Relay Feedback Circuit Low Voltage
ECM
P0690
Engine Controls Ignition Relay Feedback Circuit High Voltage
ECM
or
P0691
Cooling Fan Relay 1 Control Circuit Low Voltage
ECM
P0692
Cooling Fan Relay 1 Control Circuit High Voltage
ECM
P0693
Cooling Fan Relay 2 Control Circuit Low Voltage
ECM
P0694
Cooling Fan Relay 2 Control Circuit High Voltage
ECM
P0697
5-Volt Reference 3 Circuit
ECM
P0698
5-Volt Reference 3 Low Voltage
ECM
P0699
5-Volt Reference 3 High Voltage
ECM
P0700
Transmission Control Module (TCM) Requested MIL Illumination
ECM
DTC P0700 for the 2.0L engine
or
DTC P0700 for the 2.2L or 2.4L engine
P0703
Brake Switch Circuit 2
ECM
DTC P0703
P0705
Transmission Range (TR) Switch Circuit
TCM
DTC P0705
P0711
Transmission Fluid Temperature (TFT) Sensor Performance
TCM
DTC P0711, P0712, or P0713 for the 4T45-E transaxle
P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
TCM
P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
TCM
P0716
Input Speed Sensor Performance
TCM
DTC P0716 or P0717
P0717
Input Speed Sensor Circuit Low Voltage
TCM
DTC P0716 or P0717
P0722
Output Speed Sensor Circuit Low Voltage
TCM
DTC P0722 or P0723
P0723
Output Speed Sensor Circuit High Voltage
TCM
DTC P0722 or P0723
P0741
Torque Converter Clutch (TCC) System - Stuck Off
TCM
DTC P0741 or P0742 for the 4T45-E transaxle
P0742
Torque Converter Clutch (TCC) System - Stuck On
TCM
P0751
1-2 Shift solenoid (SS) Valve Performance - No First or Fourth Gear
TCM
DTC P0751 or P0752 for the 4T45-E transaxle
P0752
1-2 Shift solenoid (SS) Valve Performance - No Second or Third Gear
TCM
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
TCM
DTC P0756 or P0757 for the 4T45-E transaxle
P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
TCM
P0806
Clutch Pedal Position (CPP) Sensor Circuit Performance
ECM
DTC P0806 for the Getrag 5 Speed
or
DTC P0806 (MU3)
P0807
Clutch Pedal Position (CPP) Sensor Circuit Low Voltage
ECM
DTC P0807 or P0808 for the Getrag 5 Speed
or
DTC P0807 or P0808 (MU3)
P0808
Clutch Pedal Position (CPP) Sensor Circuit High Voltage
ECM
or
P080A
Clutch Pedal Position (CPP) Not Learned
ECM
DTC P080A for the Getrag 5 Speed
or
DTC P080A (MU3)
P0842
Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage
TCM
DTC P0842 or P0843
P0843
Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage
TCM
DTC P0842 or P0843
P0961
Line Pressure Control (PC) Solenoid System Performance
TCM
DTC P0961
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0973 or P0974 for the 4T45-E transaxle
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
TCM
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0976 or P0977 for the 4T45-E transaxle
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
TCM
P1101
Intake Air Flow System Performance
ECM
DTC P0101 or P1101
P1133
HO2S Insufficient Switching Sensor 1
ECM
P1174
Fuel Trim Cylinder Balance
ECM
DTC P1174
P1400
Cold Start Emission Reduction Control System
ECM
DTC P1400
P150C
Transmission Control Module (TCM) Engine Speed Request Circuit
ECM
DTC P150C
P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
ECM
DTC P1516, P2101, P2119, or P2176
P1551
Throttle Actuator Control (TAC) Motor Control Circuit
ECM
P1630
Theft Deterrent Learn Mode Active
ECM
DTC P1630
P1631
Theft Deterrent Start Enable Signal Not Correct
ECM
DTC P1631
P1632
Theft Deterrent Start Disable Signal Received
ECM
DTC P1632
P167A
ECM
P167D
Control Module Ignition Coil Internal Circuit
ECM
P1682
Ignition 1 Switch Circuit 2
ECM
DTC P1682
P1810
Transmission Fluid Pressure (TFP) Position Switch Circuit
TCM
DTC P1810, P1816, or P1818
P1811
Maximum Adapt and Long Shift
TCM
DTC P1811
P1816
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio
TCM
P1818
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio
TCM
P2088
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage
ECM
P2089
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage
ECM
P2090
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage
ECM
P2091
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage
ECM
P2096
Post Catalyst Fuel Trim System Low Limit Bank 1
ECM
DTC P2096, P2177, or P2187
P2097
Post Catalyst Fuel Trim System High Limit Bank 1
ECM
DTC P2097, P2178, or P2188
P2100
ECM
P2101
ECM
DTC P0638, P1551, P2100, P2101, P2119, or P2176 for the 2.0L engine
or
DTC P1516, P2101, P2119, or P2176 for the 2.2L or 2.4L engine
P2105
Throttle Actuator Control (TAC) System - Forced Engine Shut-down
ECM
P2119
Throttle Closed Position Performance
ECM
or
P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
ECM
DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138
P2122
Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
ECM
DTC P2122 or P2123 for the 2.0L engine
or
DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.2L or 2.4L engine
P2123
Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
ECM
or
P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
ECM
P2127
Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
ECM
DTC P2127 or P2128 for the 2.0L engine
or
P2128
Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
ECM
or
P2135
Throttle Position (TP) Sensor 1-2 Correlation
ECM
P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
ECM
DTC P2138 for the 2.0L engine
or
P2146
Injector Positive Voltage Control Circuit Group 1
ECM
P2149
Injector Positive Voltage Control Circuit Group 2
ECM
P2152
Injector Positive Voltage Control Circuit Group 3
ECM
P2155
Injector Positive Voltage Control Circuit Group 4
ECM
P2176
Minimum Throttle Position Not Learned
ECM
or
P2177
Fuel Trim System Lean at Cruise or Accel
ECM
P2178
Fuel Trim System Rich at Cruise or Accel
ECM
P2187
Fuel Trim System Lean at Idle
ECM
P2188
Fuel Trim System Rich at Idle
ECM
P2195
HO2S Signal Biased Lean Sensor 1
ECM
P2196
HO2S Signal Biased Rich Sensor 1
ECM
P2199
Intake Air Temperature (IAT) Sensor 1-2 Correlation
ECM
DTC P2199
P2227
Barometric Pressure (BARO) Sensor Performance
ECM
DTC P2227, P2228, or P2229
P2228
Barometric Pressure (BARO) Sensor Circuit Low Voltage
ECM
P2229
Barometric Pressure (BARO) Sensor Circuit High Voltage
ECM
P2232
HO2S Signal Circuit Shorted to Heater Circuit Sensor 2
ECM
P2237
HO2S Pumping Current Control Circuit Sensor 1
ECM
DTC P2237, P2243, P2251, or P2626
P2243
HO2S Reference Voltage Circuit Sensor 1
ECM
P2251
HO2S Low Reference Circuit Sensor 1
ECM
P2261
Turbocharger Bypass Valve Stuck Closed
ECM
DTC P2261
P2270
HO2S Signal Stuck Lean Sensor 2
ECM
or
P2271
HO2S Signal Stuck Rich Sensor 2
ECM
or
P2297
HO2S Performance During Decel Fuel Cut-Off (DFCO) Sensor 1
ECM
P2300
Ignition Coil 1 Control Circuit Low Voltage
ECM
DTC P2300, P2301, P2303, P2304, P2306, P2307, P2309, or P2310
P2301
Ignition Coil 1 Control Circuit High Voltage
ECM
P2303
Ignition Coil 2 Control Circuit Low Voltage
ECM
P2304
Ignition Coil 2 Control Circuit High Voltage
ECM
P2306
Ignition Coil 3 Control Circuit Low Voltage
ECM
P2307
Ignition Coil 3 Control Circuit High Voltage
ECM
P2309
Ignition Coil 4 Control Circuit Low Voltage
ECM
P2310
Ignition Coil 4 Control Circuit High Voltage
ECM
P2430
Secondary Air Injection (AIR) System Pressure Sensor Circuit
ECM
DTC P2430-P2433
P2431
Secondary Air Injection System Pressure Sensor A Circuit Range/Performance
ECM
DTC P2430-P2433
P2432
Secondary Air Injection System Pressure Sensor A Circuit Low
ECM
DTC P2430-P2433
P2433
Air Injection System Pressure Sensor A Circuit High
ECM
DTC P2430-P2433
P2440
Secondary Air Injection System Switching Valve Stuck Open
ECM
P2444
Secondary Air Injection System Pump Stuck On
ECM
P2500
Generator L-Terminal Circuit Low
ECM
DTC P2500
P2501
Generator L-Terminal Circuit High
ECM
DTC P2501
P2534
Ignition 1 Switch Circuit Low Voltage
TCM
DTC P2534
P2544
Transmission Torque Request Circuit
ECM
DTC P2544 for the 2.0L engine
or
DTC P2544 for the 2.2L or 2.4L engine
P2610
Control Module Ignition Off Timer Performance
ECM
or
P2626
HO2S Pumping Current Trim Circuit Sensor 1
ECM
P2763
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
TCM
DTC P2763 or P2764 for the 4T45-E transaxle
P2764
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
TCM
P2A00
ECM
U0001
High Speed CAN Communication Bus
BCM, EBCM, PSCM, ECM, VCIM
DTC U0001
U0073
Controller Area Network (CAN) Bus Communication
ECM, Radio, RCDLR, VCIM
DTC U0073
U0100 - U0299
Lost Communication With XXX Control Module
DTC U0100-U0299
U1000
Class 2 Data Link
DTC U1000 and U1255
U1255
Loss of Class 2 Communication
DTC U1000 and U1255
U2103
Fewer Controllers On Bus Than Programmed
DRR, IPC, Radio, SDM, VCIM
DTC U2103
U2105 - U2199
DTC U2105-U2199
023
Seat Belt Tension Sensor Circuit Out of Range
PPS
DTC 023
024
PPS Ignition 1 Voltage Performance
PPS
DTC 024
063
PPS Out of Calibration
PPS
DTC 063
064
Communication/ID Performance
PPS
DTC 064
065
PPS
DTC 065
1066
Battery Voltage Low
PPS
DTC 1066-1068
1067
Battery Voltage High
PPS
DTC 1066-1068
1068
Battery Voltage Out Of Range
PPS
DTC 1066-1068
1071
Passenger Presence System 1 Calibration Not Learned
PPS
DTC 1071 or 1072
1072
Passenger Presence System 1 Plausibility Failure
PPS
DTC 1071 or 1072
2001 - 2054
Internal Electronic Performance 1
PPS
DTC 2001-2054
202A - 202E
PPS
DTC 202A-202E
3003 - 3059
Passenger Occupant Classification Sensor Circuit
PPS
DTC 3003-3059
300A
PPS
DTC 300A
301A
PPS
DTC 301A
303A - 303E
PPS
DTC 303A-303E
305A - 305C
PPS
DTC 305A-305C
4061 - 4065
Loss Of Class 2 Communication
PPS
DTC 4061-4065
Can this be stickied .... I know someone posted an LNF list link but this is for every model.
DTC
DTC Descriptor
B0012
SDM
DTC B0012 or B0013
P0013
ECM
or
P0014
ECM
or
P0016
ECM
or
P0017
ECM
or
P0030
ECM
or
P0031
ECM
P0032
ECM
P0033
ECM
P0034
ECM
P0035
ECM
P0036
ECM
or
P0037
ECM
P0038
ECM
P0053
ECM
B0013
SDM
DTC B0012 or B0013
B0015
SDM
DTC B0014-B0045
B0016
SDM
DTC B0014-B0045
B0019
SDM
DTC B0014-B0045
B0020
SDM
DTC B0014-B0045
B0022
SDM
DTC B0014-B0045
B0023
SDM
DTC B0014-B0045
B0052
SDM
DTC B0052 or B0053
B0053
SDM
DTC B0052 or B0053
B0081
SDM
DTC B0081
B0083
Front End Sensor 1
SDM
DTC B0083-B0088
B0085
SDM
DTC B0083-B0088
B0086
SDM
DTC B0083-B0088
B0158
BCM
DTC B0158
or
DTC B0158
B0283
BCM
DTC B0283
B0685
BCM, IPC
DTC B0685
B1000
DTC B1000
B1001
DTC B1001
ROS, SDM
DTC B1001
B1004
BCM
DTC B1004
B1009
BCM
DTC B1009
B1011
SDM
DTC B1011
B1019
SDM
DTC B1019
B101D
Internal Fault
PPS
DTC B101D
B101E
ECU Error
PPS
DTC B101E
B1025
Radio
B1035
Radio
B1045
Radio
B1055
Radio
B1259
DRR
DTC B1259
B1287
Radio
DTC B1287
B1325
DTC B1325
B1370
BCM
SDM
DTC B1370
B1380
BCM
B1424
Device Voltage Low
TDM
DTC B1424
B1441
BCM
B1480
BCM
DTC B1480
B1516
BCM
DTC B1516
B1517
Battery 1 Voltage
BCM
DTC B1517
B2455
VCIM
DTC B2455
B2462
VCIM
DTC B2462
B2470
VCIM
DTC B2470
B2476
VCIM
DTC B2476 or B2482
B2482
VCIM
DTC B2476 or B2482
B2483
VCIM
DTC B2483 or B2484
B2484
VCIM
DTC B2483 or B2484
B2485
VCIM
DTC B2485
B2530
BCM
DTC B2530
B2555
BCM
DTC B2555
B2580
BCM
DTC B2580
B2625
BCM
DTC B2625
B2645
BCM
DTC B2645
B2705
BCM
DTC B2705
B2750
Horn Relay Output
BCM
DTC B2750
B2961
BCM
DTC B2961
B3006
Hood Ajar Circuit
BCM
DTC B3006
B3031
BCM
DTC B3031
B3055
TDM
DTC B3055
B3060
VTD
DTC B3060
B3105
RCDLR
DTC B3105
B3109
RCDLR
B3110
RCDLR
B3111
RCDLR
B3112
RCDLR
B3265
Trunk Relay Output
BCM
DTC B3265
B3715
BCM
DTC B3715
B3794
BCM
DTC B3794
B3903
BCM
DTC B3903
B3935
TDM
DTC B3935
B3948
BCM
DTC B3948 or B3949
B3949
BCM
DTC B3948 or B3949
B3950
BCM
DTC B3950 or B3951
B3951
BCM
DTC B3950 or B3951
B3976
TDM
DTC B3976
C0000
PSCM
DTC C0000
C0035
EBCM
DTC C0035-C0050
C0040
EBCM
DTC C0035-C0050
C0045
EBCM
DTC C0035-C0050
C0050
EBCM
DTC C0035-C0050
C0110
Pump Motor Circuit
EBCM
DTC C0110
C0131
EBCM
DTC C0131
C0161
EBCM
DTC C0161
C0176
PSCM
DTC C0176
C0186
EBCM
DTC C0186
C0196
Yaw Rate Circuit
EBCM
DTC C0196
C0201
EBCM
DTC C0201
C0252
EBCM
DTC C0252
C0267
EBCM
DTC C0267
C0277
BCM
DTC C0277
C0278
BCM
DTC C0278
C0280
EBCM
DTC C0280
C0292
EBCM
DTC C0292
C0299
EBCM
DTC C0299
C0460
EBCM
DTC C0460
C0475
PSCM
DTC C0475
C0545
PSCM
DTC C0545
C0550
EBCM, EPS, PSCM
DTC C0550
C0551
EBCM
DTC C0551
C0561
EBCM
DTC C0561
C0569
EBCM
DTC C0569
RCDLR
DTC C0569
C0750
RCDLR
C0755
RCDLR
C0760
RCDLR
C0765
RCDLR
C0775
RCDLR
DTC C0775
C0845
PSCM
DTC C0845
C0870
BCM
DTC C0870
C0895
PSCM
DTC C0895
C0899
Device Voltage Low
EBCM
DTC C0899
C0900
Device Voltage High
EBCM
DTC C0900
C1100
EBCM
DTC C1100
P0010
ECM
or
P0011
ECM
or
P0013
ECM
or
P0014
ECM
or
P0016
ECM
or
P0017
ECM
or
P0030
ECM
or
P0031
ECM
P0032
ECM
P0033
ECM
P0034
ECM
P0035
ECM
P0036
ECM
or
P0037
ECM
P0038
ECM
P0053
ECM
or
P0054
ECM
P0068
ECM
DTC P0068 or P0121
P0087
ECM
P0088
ECM
P0089
ECM
P0090
ECM
P0091
ECM
P0092
ECM
P0096
ECM
P0097
ECM
P0098
ECM
P0099
ECM
P0100
ECM
P0101
ECM
or
P0102
ECM
or
P0103
ECM
or
P0106
ECM
or
P0107
ECM
or
P0108
ECM
or
P0112
ECM
or
P0113
ECM
or
P0114
ECM
P0116
ECM
or
P0117
ECM
or
P0118
ECM
or
P0119
ECM
P0120
ECM
P0121
ECM
P0122
ECM
or
P0123
ECM
or
P0128
ECM
or
P0130
ECM
P0131
ECM
or
P0132
ECM
or
P0133
ECM
or
P0134
ECM
P0135
ECM
or
P0137
ECM
or
P0138
ECM
or
P013A
ECM
or
P013B
ECM
P013E
ECM
or
P013F
ECM
P0140
ECM
or
P0141
ECM
or
P0171
ECM
DTC P0171 or P0172
P0172
ECM
DTC P0171 or P0172
P0191
ECM
P0192
ECM
P0193
ECM
P0201
ECM
or
P0202
ECM
or
P0203
ECM
or
P0204
ECM
or
P0218
TCM
DTC P0218
P0220
ECM
P0221
ECM
P0222
ECM
or
P0223
ECM
or
P0230
ECM
DTC P0230
P0234
ECM
DTC P0234 or P0299
P0236
ECM
P0237
ECM
P0238
ECM
P0243
ECM
P0245
ECM
P0246
ECM
P0261
ECM
P0262
ECM
P0264
ECM
P0265
ECM
P0267
ECM
P0268
ECM
P0270
ECM
P0271
ECM
P0299
ECM
DTC P0234 or P0299
P029D
Injector 1 Leak
ECM
P02A1
Injector 2 Leak
ECM
P02A5
Injector 3 Leak
ECM
P02A9
Injector 4 Leak
ECM
P0300
ECM
or
P0301
ECM
or
P0302
ECM
or
P0303
ECM
or
P0304
ECM
or
P0315
ECM
DTC P0315
P0324
ECM
P0325
ECM
P0326
ECM
P0327
ECM
P0328
ECM
P0331
ECM
P0332
ECM
P0333
ECM
P0335
ECM
or
P0336
ECM
or
P0338
ECM
P0340
ECM
DTC P0340 or P0365
P0341
ECM
or
P0342
ECM
P0343
ECM
P0351
ECM
or
P0352
ECM
or
P0353
ECM
or
P0354
ECM
or
P0365
ECM
DTC P0340 or P0365
P0366
ECM
or
P0367
ECM
P0368
ECM
P0411
ECM
P0412
ECM
P0418
ECM
P0420
ECM
or
P0442
ECM
or
P0443
ECM
or
P0446
ECM
or
P0449
ECM
or
P0450
ECM
DTC P0450-P0453
P0451
ECM
or
P0452
ECM
or
P0453
ECM
or
P0454
ECM
P0455
ECM
or
P0458
ECM
P0459
ECM
P0461
ECM
DTC P0461
P0462
ECM
DTC P0462
P0463
ECM
DTC P0463
P0464
ECM
DTC P0464
P0480
ECM
or
P0481
ECM
P0496
ECM
or
P0497
ECM
DTC P0497
P0498
ECM
P0499
ECM
P0501
ECM
DTC P0501
P0502
ECM
or
P0503
ECM
or
P0506
Idle Speed Low
ECM
or
P0507
Idle Speed High
ECM
or
P050A
ECM
DTC P050A
P0520
ECM
DTC P0520
P0532
ECM
DTC P0532 or P0533
P0533
ECM
DTC P0532 or P0533
P0562
System Voltage Low
ECM
DTC P0562
TCM
DTC P0562 or P0563
P0563
System Voltage High
ECM
DTC P0563
TCM
DTC P0562 or P0563
P0571
ECM
DTC P0571
P0572
ECM
DTC P0572 or P0573
P0573
ECM
DTC P0572 or P0573
P0575
ECM
DTC P0575
P0601
ECM
or
TCM
P0602
ECM
or
TCM
P0603
ECM
or
TCM
P0604
ECM
or
TCM
P0606
ECM
or
P0607
ECM
P060D
ECM
P0615
ECM
DTC P0615
P0616
ECM
DTC P0616
P0617
ECM
DTC P0617
P0621
ECM
DTC P0621
P0622
ECM
DTC P0622
P0627
ECM
P0628
ECM
P0629
ECM
P062B
ECM
P062F
ECM
TCM
P0638
ECM
P0641
ECM
or
P0642
ECM
P0643
ECM
P0645
ECM
DTC P0645
P064D
ECM
P0650
ECM
or
P0651
ECM
or
P0652
ECM
P0653
ECM
P0685
ECM
or
P0686
ECM
P0687
ECM
P0689
ECM
P0690
ECM
or
P0691
ECM
P0692
ECM
P0693
ECM
P0694
ECM
P0697
ECM
P0698
ECM
P0699
ECM
P0700
ECM
or
P0703
ECM
DTC P0703
P0705
TCM
DTC P0705
P0711
TCM
P0712
TCM
P0713
TCM
P0716
TCM
DTC P0716 or P0717
P0717
TCM
DTC P0716 or P0717
P0722
TCM
DTC P0722 or P0723
P0723
TCM
DTC P0722 or P0723
P0741
TCM
P0742
TCM
P0751
TCM
P0752
TCM
P0756
TCM
P0757
TCM
P0806
ECM
or
DTC P0806 (MU3)
P0807
ECM
or
P0808
ECM
or
P080A
ECM
or
DTC P080A (MU3)
P0842
TCM
DTC P0842 or P0843
P0843
TCM
DTC P0842 or P0843
P0961
TCM
DTC P0961
P0973
TCM
P0974
TCM
P0976
TCM
P0977
TCM
P1101
ECM
DTC P0101 or P1101
P1133
ECM
P1174
ECM
DTC P1174
P1400
ECM
DTC P1400
P150C
ECM
DTC P150C
P1516
ECM
P1551
ECM
P1630
ECM
DTC P1630
P1631
ECM
DTC P1631
P1632
ECM
DTC P1632
P167A
ECM
P167D
ECM
P1682
ECM
DTC P1682
P1810
TCM
P1811
TCM
DTC P1811
P1816
TCM
P1818
TCM
P2088
ECM
P2089
ECM
P2090
ECM
P2091
ECM
P2096
ECM
P2097
ECM
P2100
ECM
P2101
ECM
or
P2105
ECM
P2119
ECM
or
P2120
ECM
P2122
ECM
or
P2123
ECM
or
P2125
ECM
P2127
ECM
or
P2128
ECM
or
P2135
ECM
P2138
ECM
or
P2146
ECM
P2149
ECM
P2152
ECM
P2155
ECM
P2176
ECM
or
P2177
ECM
P2178
ECM
P2187
ECM
P2188
ECM
P2195
ECM
P2196
ECM
P2199
ECM
DTC P2199
P2227
ECM
P2228
ECM
P2229
ECM
P2232
ECM
P2237
ECM
P2243
ECM
P2251
ECM
P2261
ECM
DTC P2261
P2270
ECM
or
P2271
ECM
or
P2297
ECM
P2300
ECM
P2301
ECM
P2303
ECM
P2304
ECM
P2306
ECM
P2307
ECM
P2309
ECM
P2310
ECM
P2430
ECM
DTC P2430-P2433
P2431
ECM
DTC P2430-P2433
P2432
ECM
DTC P2430-P2433
P2433
ECM
DTC P2430-P2433
P2440
ECM
P2444
ECM
P2500
ECM
DTC P2500
P2501
ECM
DTC P2501
P2534
TCM
DTC P2534
P2544
ECM
or
P2610
ECM
or
P2626
ECM
P2763
TCM
P2764
TCM
P2A00
ECM
U0001
DTC U0001
U0073
DTC U0073
U0100 - U0299
DTC U0100-U0299
U1000
Class 2 Data Link
DTC U1000 and U1255
U1255
DTC U1000 and U1255
U2103
DTC U2103
U2105 - U2199
DTC U2105-U2199
023
PPS
DTC 023
024
PPS
DTC 024
063
PPS
DTC 063
064
PPS
DTC 064
065
PPS
DTC 065
1066
Battery Voltage Low
PPS
DTC 1066-1068
1067
PPS
DTC 1066-1068
1068
PPS
DTC 1066-1068
1071
PPS
DTC 1071 or 1072
1072
PPS
DTC 1071 or 1072
2001 - 2054
PPS
DTC 2001-2054
202A - 202E
PPS
DTC 202A-202E
3003 - 3059
PPS
DTC 3003-3059
300A
PPS
DTC 300A
301A
PPS
DTC 301A
303A - 303E
PPS
DTC 303A-303E
305A - 305C
PPS
DTC 305A-305C
4061 - 4065
PPS
DTC 4061-4065
Sl0wbaltSS
Nov 21, 2018 11:11 PM
