couple issues
weather went from about 40 to 65ish in one day. car as showing high stft and ltft and must have been high enough to throw lean code.
kinda wierd also idling pretty often the engine will kinda lope a little bit and the stft and ltft will both go to 0 and vacuum goes to 15ish, for about 2 or 3 seconds then it smooths out and stft ltft come back to moving around and vaccum goes to normal 19ish. seems to happen more often with defroster/ac compression on. kinda weird?? normal?? |
