Cruise Control
Old Sep 12, 2007 | 04:11 AM
duster74gold's Avatar
Cruise Control
I had an issue tonight with my cruise control not engaging on my 05 SS/SC. I was driving at about 70mph down the freeway and I turned on the power button and hit SET but the CRUISE ENGAGED message just briefly flashed on the DIC and no engagement. After pushing the SET button many times, I stopped even getting the brief engaged message and nothing would happen. Any thoughts or past experiences?
Old Sep 12, 2007 | 09:16 AM
Coblasts's Avatar
Seems alot of people had problems with the Clutch switch and or break switch,are your tail lights staying on(brake switch) I am not sure how to check the clutch switch other than getting down there and inspecting it visually(make sure the clutch pedal arm is making contact with the switch) and also listening for the click.
Old Sep 12, 2007 | 04:21 PM
tiny's Avatar
sometimes my brake is very slightly depressed, and it wont work
try pulling up on the brake when you set it, same thing with the clutch
Old Sep 12, 2007 | 04:34 PM
fr33k's Avatar
Real common problem with the balts. On some or all the balts, there's a felt pad that contacts the switch instead of metal. When that pad is indented from average use, the switch is out of alignment and stays on sometimes when you dont know it. It could be coming from your brake light switch or from your clutch cruise release switch.
There's 2 bulletins for this. Ones a TSB(technical service bulletin) and the other is a PI (preliminary information)
The TSB is here:
http://fr33k.5gbfree.com/06-08-68-002.htm
And the PI is here:
http://fr33k.5gbfree.com/PIP3673.htm
Old Sep 12, 2007 | 04:35 PM
RaineMan's Avatar
This is a very common occurance on all Cobalts with cruise... whether manual or automatic... and it is typically caused by nothing that the driver did. The cruise module will store a code every time this happens.
Take it to the dealer... they will reflash the cruise computer... and it might fix the problem. It happened 3 times in the year I had my 2.4... hasn't happened yet on my SS/SC. Just luck of the draw.
Old Sep 12, 2007 | 04:45 PM
Mrmaasta's Avatar
Agree, just take it to the dealer and they will flash it. I had it happen at about 30k kms. Driver error they said.
Old Sep 13, 2007 | 12:01 AM
Thank you guys for the info. I was afraid I had a bad switch in the steering wheel. I don't like playing with electronics by an airbag. Call me paranoid....
Old Sep 13, 2007 | 12:08 AM
blissmaster13's Avatar
I took mine in for that problem 3 times. On the fourth time they just replaced my switch. No problems any more.
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
