Cruise Control Broken/shift knob
Old Feb 17, 2007 | 12:47 PM
mo1684's Avatar
Unhappy Cruise Control Broken/shift knob
so about 2 weeks ago my cruise control just stopped working. the next day the cap on top of my shift knob snaps off. i'm like wtf?!?! i'm really big on using my cruise control because i have a tendency to get a lot of speeding tix (althouugh i have'nt had any in this car yet). so i call up the dealer and they say "sure, we'll just order those parts for you and put them in." i go there they don't have the parts. not that the shift knob matters that much, i mean i could just go w/ an after-market, but the reverse lock-out doesn't really bother me much. anyways, back to the cruise control, the tech guy there gives me some explanation stating that the reason that the cc isn't working is b/c there is some connection to the clutch not letting it. has anyone else heard of this problem or encountered it?
p.s. anyone else lose the cap ontheir shift knob, i think it may be due to cold weather?
Old Feb 17, 2007 | 12:56 PM
SS/SC05/19/05's Avatar
The cap on my shifter fell off also.. I just super glued it back on.. My shifter knob also pulls of sometimes when i shift when its warm out...
Old Feb 17, 2007 | 01:02 PM
BLKSS's Avatar
Ive had two shifter knobs reinstalled and they didnt last either, the only way not to break it is by somehow shifting without touching the top of the knob (kinda hard to do). Ive asked my dealership to install a B&M short throw but they said NO. I told them I needed a shifter that didnt fall apart. They didnt care.
Old Feb 23, 2007 | 06:45 AM
joddypoo's Avatar
My CC just died a few nights ago. Takin' her to the dealer today. Did your dealer fix it? Give you any hassle?
Old Feb 23, 2007 | 06:52 AM
1gmfanatik's Avatar
GM now sells the Hurst shifter. Which I would believe that if they were to be selling it, that they would be able to install it and cover under warranty
Old Feb 23, 2007 | 09:22 AM
cobi's Avatar
If the clutch switch is making connection you will not be able to use the CC try lifting the clutch pedal from the back with your foot before you use the CC. This can happen by resting your foot on the clutch when not in use.
That being said my CC went out on me a few days ago and lifting the clutch with my foot did not work. So I unhooked the battery for a while (while I washed my car) to reset the PCM and voila it worked again. I suggest you try the same I think it only takes about 10 minutes with the negative terminal unhooked to reset the PCM.
Old Feb 27, 2007 | 03:47 PM
mo1684's Avatar
actually im at the dealer now, this is my 2nd time here. last time i called in advance for them to order parts, and they didnt. so now im here and ill update whether or not they fix it.
Old Feb 27, 2007 | 03:56 PM
Cobalt_SSTuner's Avatar
viva la revolution!
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
jrocstar
Sep 26, 2015 11:42 PM
