Cruise Control doesnt work
my cc wont set....i hit the button to set it and all it does is juz flash really fast cruise engaged and it doesnt work....everything else on my steering wheel works except that....neone kno y that might b
there are multiple threads on this issue...
if you rest your foot on the clutch it thinks it mabe engaged and with give a false reading to the ECU saying your clutch is always engaged...
what you need to do is disc the batter for a few min to reset the ECU and you will be on your way, it used to happen to me all the time
so i juz disc the battery for a few and then plug it back and it should b fine...ne reason y that happens...i had the kar at the shop for a new clutch do u think when they unplugged it that it screwed it up
My car just did this a couple days ago. I pulled up on all the pedals as I went down the highway to make sure the switches weren't tripped. I shut the car down and fired it back up going down the highway and no change. I got in it the next day and the problem fixed itself and has been fine ever since. I would just do as suggested, disconnect the battery and see if that fixes it. Strange problem.
