Curring the factory antenna?
Old Apr 20, 2007 | 08:38 PM
cobaltssTH's Avatar
my antenna wont come off with any amount of force. so what do you cut it with. whtat tool did you use. and did you lose ALL reception. i mostly listen to my ipod so it really doesnt matter
Old Apr 20, 2007 | 08:44 PM
XM15's Avatar
Maybe if you just get a longer wrench to put more torque on it. Mine was pretty tight as well, but it came right off with a little persuasion.
Plus, I'm assuming that you already purchased a shorty anyway, so you might as well get your money's worth, right?
Old Apr 20, 2007 | 08:46 PM
cobaltssTH's Avatar
in my manual it says it wont come off.
Old Apr 20, 2007 | 08:49 PM
Red06LS's Avatar
It comes off, believe us. Use some elbow grease.
Old Apr 20, 2007 | 08:54 PM
c0ld29's Avatar
yep it comes off. Mine actually lost some of the black paint on the bottom from me turning so hard.
also, make sure your turning the right way haha
HackAbuse's Avatar
I pulled mine off, and shrinkwrapped the small screw that was left, i have the ultimate shorty antenna mod.
I dont use the radio at all anyway, when im not listenin to a CD i have XM on
Old Apr 20, 2007 | 08:59 PM
tombomb's Avatar
^^^^^definatley sounds like a "hack job" no pun intended
mine also came off with a cresent wrench, got my antenna from AntennaX
Old Apr 20, 2007 | 09:00 PM
HackAbuse's Avatar
heh, it doesnt look to bad though
Old Apr 20, 2007 | 09:08 PM
JohnnySasakiMGS's Avatar
Righty tighty, Lefty loosie.
Old Apr 20, 2007 | 09:24 PM
cobaltssTH's Avatar
i know. it wont budge. just tell me how to cut it
Old Apr 20, 2007 | 09:29 PM
c0ld29's Avatar
get some hedge clippers and go at it
Old Apr 20, 2007 | 09:39 PM
shadowfaxss's Avatar
Heat the base up with a hair dryer.....make sure it gets hot to the touch....then break it loose with the wrench.
Old Apr 20, 2007 | 09:40 PM
cobaltssTH's Avatar
your kidding right? me and my dad both tried to unscrew this thing. IT HAS NOT MOVED. is there a certain place thats better to unscrew it. this antenna is really starting to **** me off
Old Apr 20, 2007 | 09:45 PM
HackAbuse's Avatar
Open end wrench and a breaker bar?
Old Apr 20, 2007 | 10:34 PM
Grimsaviour's Avatar
Are you using a wrench to get it off or are you trying to do it with your fingers? Theres two flat spots at the bottom so you can use a wrench. It really shouldnt be that hard to do. I take antennas off all the time at work i'm a bodyman. If you strip it use a small pipe wrench or visegrips. But i've never stripped an antenna and i've taken off hundreds.
And you will lose all reception, no antenna= no radio
Old Apr 21, 2007 | 02:51 AM
Red06LS's Avatar
True my antenna became out of service after i bent the **** out of it so i dotn have one on right now and im just glad i have a good cd collection.
Old Apr 21, 2007 | 10:49 AM
Halfcent's Avatar
I'm old school
Please do not "cut off" your antenna. It simply screws off. Get some help if you are having trouble.
Old Apr 21, 2007 | 01:27 PM
CobaltDude81's Avatar
haha on my cavalier the antannae would loosen up on its own.
Old Apr 21, 2007 | 11:28 PM
cobaltssTH's Avatar
ive triedmu dad tried, which he as strong as anybody i know. it wont come loose
Old Apr 21, 2007 | 11:30 PM
MISSMATCHEDFACES's Avatar
i curr my attenna off all the time
Old Apr 21, 2007 | 11:53 PM
cobaltssTH's Avatar
shut up i was celebrating 4-20
Old Apr 22, 2007 | 05:30 AM
Take it to a bodyshop. If they charge you then they are ******** but hey, you can't have everything in life i guess.
Are you wanting to replace it with a shorty or what?
Old Apr 22, 2007 | 06:08 AM
JRelly's Avatar
haha mine did to...but the atenna on the balt just needs a lil tough love just keep trying. it will come off i promise
Old Apr 22, 2007 | 10:16 AM
Brian's07SS's Avatar
bought a shorty antenna(didnt fit BTW)came right off with my fingers.
get a good pair of ViseGrips and you should be good... and are you getting it at the bottom of the Antenna itself or on the part thats attatched to the car? Dumb question I know but needs to be asked.
Old Apr 22, 2007 | 11:28 PM
Henroid2's Avatar
im having the same problem he is having, mine WILL NOT come off, the base inside the trunk just spins with it, its on that tight, ive tried everything, wd 40, heat, fingers, wrench, everything, now its just crooked and everytime i look at it i get pissed off. I took it to GM and they said they wouldnt take it off because for some reason sometimes they just dont come off and if you snap it inside the trunk, you have to replace the entire thing, and its $80
