Dash lights out...
Old Feb 26, 2008 | 08:22 PM
wisemanonice's Avatar
Dash lights out...
I staarted my car tonight and my spedo, boost, RPM, and console lights are all out. also I think I smelled buring likr electrial burning. so I turned the car off and restarted, the smell is gone but problem is there...
Old Feb 26, 2008 | 08:23 PM
Super_SS's Avatar
burned fuse...fuse box located in passanger side left console
Old Feb 26, 2008 | 08:30 PM
can I see the box if I just look under the dash, or do I have to move things around? also what could have caused something like that?
Old Feb 26, 2008 | 10:38 PM
blu3_v1p3r's Avatar
console lights are actually part of the parking light syatem... i had that problem when i wired up my halos... i guess a live wire touched something, and my speedo, rpm, and radio lights didn't work.
its locateed under the hood..
Last edited by blu3_v1p3r; Feb 26, 2008 at 10:38 PM. Reason: Automerged Doublepost
Old Feb 26, 2008 | 10:43 PM
blk ss/sc 1's Avatar
blown fuses just happen sometimes.. could be a few things like blu3 said wires could be touching or dirty wiring or contacting.. but just go replace it and u shouldnt have another problem.
Old Feb 27, 2008 | 09:51 PM
thanks guys. I did have halos put in a couple months ago. I will go check the fuses
*bump* Ok update time. I looked at the fuses, nothing seemed wrong at a glance. Its dark out so idk. But my taillights also dont work, nor do my parking lights. My brakes show up though. Which fuse should I be looking for? (name)
Last edited by wisemanonice; Feb 27, 2008 at 10:04 PM. Reason: Automerged Doublepost
Old Feb 27, 2008 | 10:13 PM
Sandantos's Avatar
I don't know much about fuses, but I'm thinking check your manual, it has diagrams of which fuses are where, check the ones that aren't lighting up. That'll be a good start.
Old Feb 27, 2008 | 10:19 PM
what does a bad fuse look like?
Old Feb 28, 2008 | 03:08 AM
blu3_v1p3r's Avatar
a bad fuse... when you look at the colored part of the fuse you can still see through it, and in side of it there is a peice of metal connecting the two prongs that insert into the fuse box, if the fuse is blown it will be disconnected from the prong...
Also, I'm positive that its your parking light fuse now, its in the fuse box under the hood i belive its a 15 amp fuse and if you've never had to replace a fuse here is a quick how to...
1. Pop the hood
2. Open the hood
3 Locate the fuse box and open it, it will be on the drivers side
4. After the fuse box is open look at the under side of the cover
5. Match the location of the fuse labeled for the parking lamps on the underside of the cover, to the correct location of the fuse in the fuse box
6. Pull the fuse out using either needle nose pliers, or the fuse puller supplied with your car.
7. Examine the fuse to see if it is blown. (Here's where it gets tricky LOL)
8. If it is not blown you can replace that same fuse. If it is blown look at the blow fuse and find the number on it and replace it with a fuse that the has the same number on it.
(For those that can read number they are color coordinated... so if the fuse is blue replace it with a blue fuse)
9. Check your lights, or what ever it is that your replacing the fuse for.
10. Upon a sucessfull check close the fuse box.
11. When the cover is secured, close the hood.
12. After the job is done go grab a cold beer and feel great about you new fuse job.
also if the fuse continues to blow, check the wiring to see if there is a bare wire anywhere... if so cap it off and tape it up, unless it connects to something... in that case reconncet it and tape it
Old Mar 1, 2008 | 01:04 PM
I replaced the fuse. checked the lights. started the car, popped the fuse again. wtf
Old Mar 1, 2008 | 01:06 PM
ssweeet's Avatar
Check your parking lamp fuse. When I had my gauge cluster lights out, the parking fuse located in the engine bay was burnt out. Try that. When I replaced it, my gauge cluster lights came back on. I also noticed that my taillights didn't work. Brake lights were fine but the taillights were out and when I replaced the parking lamp fuse, everything worked fine.
Old Mar 1, 2008 | 01:09 PM
I tried that. they all worked until I started my car and that same fuse popped again
Old Mar 1, 2008 | 01:26 PM
blu3_v1p3r's Avatar
do you have halos? if so how are they wired? check the headlight wires, and the tail light wires for a loose wire, or a wire that is broken or touching any type of metal.... you can also try a bigger fuse... i don't really recommend it but, maybe you just have to much stuff hooked up to a fuse that is too small...
Old Mar 1, 2008 | 07:30 PM
Coblasts's Avatar
There was a info bulletin out on this.
Wire behind the radio chaffing and grounding out .
I will see if I can find it again.
Old Mar 1, 2008 | 10:31 PM
another update. I replaced the fuse again. and that black modular that goes to the 3 leds at the top, started smoking and stuff. So as of now, I cut those wires and im driving around with just those 3 lights out. the rest work fine. any reasons or sudjestions(sp)?
Old Mar 2, 2008 | 03:58 AM
EmperorJJ1's Avatar
if you have halos and you didnt run seperate wiring for the aftermarket halos or leds then your overloading the wire with too much current and its heating up and poping fuses instead of burning your car. re wire
Old Mar 2, 2008 | 10:01 AM
looks lke I have to do it tuesday... man that sucks
Old Mar 2, 2008 | 05:00 PM
EmperorJJ1's Avatar
not really its not quite that bad if you use a relay
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
