Dearship says they cant fix my in warrenty LNF
2010 LNF 34K miles, stage 1 installed in 2010
I'm getting intermittent lost of power while driving(feels like a loss of a cylinder). Sometimes it wont start, or will start but idle hunts between 500 and 1000 RPM then will stall. Most of the time it starts and runs OK. I'd say power loss happens about 3-5 times a week. Sometimes I'll get a check engine lite. This has been going on/getting worse for about 3 months.
Codes Dealer pulled were: P0106, P0101. P0300. P0301. P0302. P0303. P0304
They state "the concern is a characteristic of stage 1 kit, there is no correction at this time" bullshit of course.
I'm calling Customer Care tomorrow, but I thought you guys might have some ideas.
1 Post
In case you don't know what the codes are.
P0106
Manifold Absolute Pressure (MAP) Sensor Performance
P0101
Mass Air Flow (MAF) Sensor Performance
P0300
Engine Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0106
P0101
P0300
P0301
P0302
P0303
P0304
Calling customer service was a good idea they should help otherwise seek out a better dealer
People on here have been to all kinds of shitty dealerships for some reason I found a good one they are out there tje one I dwal with has went above and beyond multiple times for me. Once the replaced a side skirt under bumper to bumper warranty even though it was most likey my friend that damaged it, another time they replaced my ignition even though their tsb doestbinclude 2010 models.
Moral of the story find a better dealer they dont all suck but if that dealership thinks its normal for gms1 to throw all those codes i wouldn't let them near my car anyway.
On a side note who installed gms1? If gm did it they more than likely used some shitty quick splices which are known to fail causing all sorts of codes
Stage 1 was installed by the same dealer. I bought the adapters, so they didn't have to splice them in. Of course one was bad so they decided to splice it in without calling me. They did solder the connections and shrink tubing them, the work looked OK to me.
If you need any assistance with this, please feel free to send a private message to us! We are Customer Care as well, and we can certainly look into this further for you.
Patsy G
Chevrolet Customer Care
For what it is worth the 5 year 100k drivetrain warranty only applies to hard parts like pistons, connecting rods, block, transmission, differential, etc... it does not cover for electrical units, sensors or accessory items. Unless one of those items are damaged and causing the issue they are correct to deny it under warranty.
