Distortion in speakers
Old Feb 11, 2007 | 08:38 PM
artawesome's Avatar
at 1st i thought it was me. then i thought it was my cd player and the music. but the more i hear it the more i started hearing distortions in my drivers side speaker. has anybody else had this happen? wondering if something could have got knocked loose with me slamming my door. is it warranty time?
i also have to ask, if i take it in for a look, what does the dealership look for. i dont want to hear " we cant find anything the matter" bit that they practice.
thanks guys!
Old May 1, 2007 | 02:41 PM
cachalot's Avatar
I have the same problem. Showed to dealer quick and they said it was something in the door and not the speaker itself. I'm thinking about taking the door apart myself and trying to find the rattle rather than having to hear "we couldn't get it to make the noise."
Old May 4, 2007 | 01:41 PM
artawesome's Avatar
thanks for the response but it drove me nuts to the point i traded the car in and got the ss s/c kidding, thats not the reason. but still
Old May 5, 2007 | 01:33 AM
GUIDARE's Avatar
The dealer I went to has a cd that will show up any problems with the sound system speakers. They used it on my sound system to see if the water in the trunk screwed up the speakers. I guess it has a full range of tones.
Old May 19, 2007 | 01:55 PM
Flyncobalt's Avatar
I have the same problem on my 2006 cobalt. Front driver door speaker sounds like crap. So first I replaced the speaker, sounded ok for a couple of days then started distorting like crazy. So now I figured its the stock radio. I went and bought the Sony BT2500 for the bluetooth. As I was installing it I heard the driver speaker distorting again. Now im pissed. Turns out, the original cable harness wiring right at the radio connector was a bad connection to that speaker. All fixed now. Hope this helps.
Old May 30, 2007 | 07:36 PM
cachalot's Avatar
I took the door apart yesterday. Pulled the speaker out and it sounded fine by itself. I believe the problem was with the plastic sheet between the inner door and the door panel. The sheet was fluttering with the bass of the speaker so I secured the plastic to the door frame in a couple of places using zip ties. No more problem. Warning: be careful if you take the door apart with the Pioneer tweeters. There is a metal clip attaching the tweeter panel to the window frame and two plastic clips holding it to the door panel. The plastic tabs broke when I pulled on the tweeter panel. If anyone takes the door apart just pull the top of the panel releasing the metal clip and leave the rest attached to the door panel, removing it all as one piece.
Old Jun 1, 2007 | 12:23 AM
Fade.To.Black's Avatar
i have the same problem, in the drivers side door.. ive already had ALL the speakers replaced by warranty, and it still comes back at times.. its weird though, somedays its distorted and other days its PERFECTLY fine, and it seems whenever i take it to the dealership, it works fine, its BS!
xxenjoi11
Sep 29, 2015 12:36 PM
brickloaf
Sep 25, 2015 09:10 PM
dieGone
Sep 23, 2015 10:20 AM
Turbo6
Aug 27, 2015 08:37 PM
