Does'nt Start Cobalt LS 2006
Old Oct 19, 2018 | 05:14 AM
bobleponge187's Avatar
Hi, I'm new on this forum . I love my car but he doesn't start .1: Put the key in the swith . 2: Everything work BUT THE ENGINE DOESN'T START !!!! The first time it's apen I sent my car and cost 559,99 without taxe for 6 hours of research ! He did that the first time it's where because I change de Clutch . The last time I went see my friend everything where okay .But when I get out my car an Bunch of Wires feelt on my feet so I took it back to the "ritgh place" and get out see my friend. When I try too left my friend house he doesn't stiill starting . I tried to boost it but its doesn't work Does some one know what's happen
:furieux:: jaser
Old Oct 19, 2018 | 08:02 AM
jdbaugh1's Avatar
We are going to need more information before we will have any chance of assisting you. What we know so far:
  • You installed a clutch yourself once and after you were finished the car wouldn't start so you paid someone 560 to fix it. So they fixed it and everything was working fine?
  • Car was working normally but then wires fell down by your feet so you took it to get looked at by your friend (Did your friend do anything to the car?) then when you tried to leave and your car wouldn't start?
    • Was your car running when the wires fell by your feet or would it not start after that happened? To clarify, your car started fine before the wires fell and then wouldn't start after the wires fell?
We need to know specifically what happened to the car between when it would run fine and when it would no longer start. Also, the symptoms you are witnessing when you try to start the car such as do your dash lights turn on like normal? Does your starter click or anything?
Old Oct 19, 2018 | 08:49 AM
My car was running correctly .Until the bunch of wire drop down but it didnt make stop de car I Shut it off by my self and when a take my car again he didnt start
Old Oct 19, 2018 | 08:51 AM
jdbaugh1's Avatar
Have you inspected the wires for any breaks, loose connections, or exposed wire cores?
Old Oct 19, 2018 | 08:55 AM
Yeah I does'nt see some thing wrong. Everything where wooking correctly until I shut it up
Old Oct 19, 2018 | 06:50 PM
I just reamember I Did new hole for a spoiler last week and it's rainy outside last day.�������� Maybe water get inside the old holes and jump off my fuse ?!?!
Old Oct 20, 2018 | 09:52 AM
jdbaugh1's Avatar
Do your dash lights or anything come on when you turn the key on?
bobleponge187
2.2L LAP Performance Tech
Oct 19, 2018 09:48 PM
yellcobalt
Mar 10, 2018 06:11 PM
Supercharged06SS
Jun 21, 2014 11:42 PM
mason753
Mar 25, 2012 08:21 AM
tony2toness/sc
Nov 18, 2010 05:08 PM
