Driver Door Problems
Old Oct 27, 2010 | 01:46 PM
ezekielguy86's Avatar
Ok first off I would like to say hey Im new to the forum. I hate I have to start off with a problem but here it is. I bought this car over the weekend and this problem started yesturday. The driver door will not open from the inside. I can pull hard on the outside handle a couple time and it will open then. It just does it over and over don't know what to do about it. Not like I can take it to the dealer without paying a arm and leg since its out of warrenty. Let me know if you have the fix. Thanks
Old Oct 27, 2010 | 01:57 PM
09turbo's Avatar
First, welcome to the mad-house lol. And 2nd... so the door will open eventually? Check all the latches and linkages for the door/handle. Its not hard to pop off the door panel. How are the hinges? What year is it?
Old Oct 27, 2010 | 02:01 PM
Its a 06 SS/SC with almost 80k hinges look to be fine.
Old Oct 27, 2010 | 02:08 PM
09turbo's Avatar
Hmm... Did you check the door striker, or any of the linkages?
Old Oct 27, 2010 | 08:41 PM
BARON420's Avatar
does the inner door handle feel light weight / not connected? this occurs mostly when raining out?
Mine did this too, when I bought it... alot of lube later\.
it has to do with the power lock not fully disengaging the lock
mechanism.. a lot of lube in inner door lock...alot of use of power door lock..
use flat head screwdriver to move lock mechanism in inner door
P.S - stuck inside? wiggle lock top - up and down, with alot of movement
Old Oct 27, 2010 | 11:02 PM
Thats what it must be it was raining today and it feels like the inner door handle has nothing hooked to it. Is there a forever fix for this.
Old Oct 28, 2010 | 12:44 AM
BARON420's Avatar
take the door apart and clean linkage or free/grease it..
this is what I did:
worked it. I mean worked it! use the power locks over and over
use white lithium grease on lock mechanism
its either a build up of grease/rust which is causing the binding
or electrically moisture is effecting it
I have not had a problem since spring.... that dam door!!!
Old Oct 28, 2010 | 07:41 AM
Thanks I will have to give this a try sunday.
Old Oct 28, 2010 | 10:08 AM
BARON420's Avatar
took me about 3 sundays worked it for an hour or so each time lol
I think I used alot of wd-40 too, watch for drip hole bottom corner door..GL
Old Oct 29, 2010 | 09:51 AM
Erod's Avatar
Moderator Alumni
moved
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
