Driver floor soaked/vent
Old Apr 26, 2011 | 03:21 PM
BeradSS's Avatar
2 times this week i have had my driver floor soaked but what i dont understand is where its comming from, just the center of the floor is wet, no trails of water or drip marks leading to it, just soaked in the center? vaccumed about 16oz of water saturday now its about the same. anyone have a similar problem?
Old Apr 26, 2011 | 03:52 PM
xmusic_addictx's Avatar
I actually had my passenger side do this one time.. just made sure all my weatherstripping/door mouldings and what not were secure and not cracked.
Haven't had it since other then the time I left the sunroof open and it started to rain
Old Apr 26, 2011 | 07:52 PM
BackInBlack's Avatar
Maybe a grommet has come loose in the firewall? Sounds pretty weird.
You sure it's water, right?
Old Apr 26, 2011 | 07:55 PM
BeradSS's Avatar
Pretty sure, Its been raining alot lately and it doesnt have an odor. i know i need to start pulling some of the interior pieces off but im afraid im gonna break something
Old Apr 26, 2011 | 08:17 PM
Well as long as it's water and you're sure of it... then it should be an easy fix, although maybe hard to find.
If not... most probably your heater core is leaking. I would have called condensation off of your evaporator core but it wouldn't be leaving THAT kind of water on the floor.
Old Apr 26, 2011 | 11:24 PM
CelphTitled's Avatar
mine did this...and if it is the same you need to take the headliner back and clean out the run off for the sun roof...there clear tubes that go back and forth...
Old Apr 27, 2011 | 12:52 AM
06SS ALL DAY's Avatar
this happens to alot of srt's. for them its that door that opens and shuts when you put the air on recycle air. its called the blend door or something. thats how it leaks in for those. idk thats my 2 cents tho
Old Apr 27, 2011 | 07:08 AM
NCC-2000's Avatar
Sunroof drain would be my first bet. It runs down the A-Pillar then outside but if it plugged up or disconnected along the way the water has nowhere to go but down.
Old Apr 27, 2011 | 07:30 AM
rukkee's Avatar
I just had to fix the sunroof drain on my wifes malibu .... water was running down the inside of the A pillar and puddling on the floor. I pulled the Apillar molding and the headliner back a bit and saw the drain had pulled out of a 45* elbow fitting.
Old Mar 25, 2012 | 11:43 PM
Holly2007's Avatar
How do you get to the sunroof drain? I have mysterious puddles on my drivers side floor now that its been raining and I wanna check this first since it seems to be a common problem
Old Mar 26, 2012 | 10:44 AM
Chevrolet Cust Svc's Avatar
Holly2007,
Were you able to access the sunroof drain? Hope your investigations go well!
Sarah
GM Customer Service
Old Mar 29, 2012 | 08:49 PM
Holly2007's Avatar
So I found the leak and it was the sunroof drain. Unfortunately the hole it goes in on the side was sealed shut with tape which leads me to believe it was never put in to begin with. Just my luck! Spent 2 hours today vacuuming out water
Old Apr 22, 2012 | 12:36 AM
cobaltbuddy89's Avatar
I have this same problem with water dripping out from under my dash and all along the A-pillar. So is this sunroof drain something I will have to replace or simply an easy fix?
Old Apr 22, 2012 | 02:28 PM
Nvm. I tried pouring some water into the drain and saw it was all draining in under my dash so I went in and ripped off the A-pillar and saw my hose was simply just off. So I reconnected it and tried pouring some water down it agian and BAM! it worked like a champ! Now Im just stuck cleaning up all the dirtand crap that got into my headliner.
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
