E-Brake problem...
E-Brake problem...
I just went to pull my E brake the other day, nothing out of the ordinary, and it just had like zero resistance on it...
Like you can pull it ALL the way up.. I'm not saying like I struggled pulling it up before, but you know there's like a little tention on it... now there's like nothing..
Also, it doesn't work like it did.. Like I can be driving normal, pull it all the way up (I know that's not a good idea, but I just wanted to test it out) and it'd be like me riding the brakes slightly...
I always (did) park my car in neutral with the E brake, and the E brake isn't strong enough to let me park ANYWHERE while in neutral..
Any ideas on what happened? Possibly snapped the cable? idk.. HELPPPPPPP
Thanks!
Thanks!
Since then, or prior too? Answer to both is no
Does it pop out just like the dash trim?
Now I feel like a ******* idiot... just went out there, popped the pieces off easily.... and saw one of the cables was unhooked from that little bracket thing.. hooked it back up and i'm good.. pulled the e brake a couple times and it popped back out.. just put zip ties in there and they appear to be holding for now.. when zip ties snap, i'll actually just put some force into it and bend the bracket thing
bump this madness, i went to park today an my ebrake had waayyyy 2 much play...popped the cupholders out an both of the cables are still attached... brakes still work fine, an if i tug on the ebrake while i movin, the "brake light" comes on, an it pulls me as if i ripped the ebrake up, but its only when i feel like ima snap the ebrake off...
any help/suggestions??
Okay, heed this caution, I had this exact same thing happen to me like 2+ years ago and I thought nothing of it. The e-brake esssentially was inoperable even with the cables inserted into the guide. Finally got around to taking it to the dealership b/c the driveway at my new house is on a hill and it just so happens that my ebrake was dragging on my rotors - ruining my calipers, rotors, and pads. I felt absoluely no drag on the car the entire time i was driving it and now i have to shell out almost $1000 on repairs. Make sure your not getting any drag on the rear wheels.
hmm... ima check my calipers tomorrow an see if they're stickin or anything.. I've checked some other threads an it might be my ebrake handle that's gone out, an since I'm JUST out of Warranty
I'll hit up the junk yard an see wat I can find
I've had this problem two times. The first time it was a loose nut (Picture below) the second time my pads just really needed to be replaced.
To get to the bolt you just have to pull the cover off your e-brake handle and it's at the base.
Could be a caliper issue as well the ebrake mechanism
In the caliper it's self can seize up not allowing the cables to come
Loose after the ebrake is disengaged causing premature pad and rotor
Wear, If that is the case 9xoutta ten you will need
A new caliper
A new caliper
but it doesn't feel like its ridin the brakes tho, Ima look for that bolt tomorrow, I already got the ebrake cover off, I didn't see anything, but the piece that clicks inthere, was jus sittin around
I called up GM and complained to them that it was a safety hazard. Took the car back in and they replaced the calipers and pads under warranty and what do you know?! I barely pull up on the e-brake and the rear wheels lock up completely. Yup, definitely wasn't suppose to do that from factory
