ems fuse keeps blowing
Old May 21, 2009 | 10:03 PM
demon2003's Avatar
Every time i get on to it the fuse blows throwing all the codes in the sticky anyone else have this issue? whats the fix? I am bout to jst take it to the stealership if i cant get this resolved. I do get a catalyst code once in a while too.
Mods:
Full hahn exhaust
hahn header
gm stg 2
42# injectors
3.1" pulley
injen intake
Old May 21, 2009 | 11:36 PM
Coblasts's Avatar
I would check the clutch position sensor wires under the dash ,its fed from that fuse and one of the wires could be wore through shorting out.
Ems fue feeds
clutch switch
Maf and Iat sensor
O2 sensors
Evap canister purge selinoid
Check for pinched wiring leading to any of these,but with your explination I would start with anything that might be pinched when the motor shifts back when you punch it.
O2 sensor wiring along the back of the engine or anything that you might of worked on related to those parts that the fuse feeds.
Old May 22, 2009 | 06:53 AM
demon2003's Avatar
yea i checked it the other day after reading the sticky looks fine i guess it might not be anyone else have it blow all the time?
Old May 25, 2009 | 03:51 PM
demon2003's Avatar
bump for a fast moving forum
MrInsanityWolf
Sep 29, 2015 04:54 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
breds2k
19
Sep 21, 2015 10:24 AM
