Eng power reduced?? car stalled.. HELP!
i have an 05 ss/sc and on my way to wrk the other day it suddenly stalled and flashed eng power reduced i tried startin the car twice and no go it just puttered and died again. after sittin for about 5-10 min the car did start but now im throwin a check engine light. if u can help me diagnose the problem tht wld be great. thanks.
yep happened to me 2 days ago..what mods do u have???? mine ended up being a p0069 and alot of other codess. but the p0069 comes around...which is i belive supercharger inlet pressure/baro...hows the wheather been where u live???changed alot?? also try cleaning out ur throttle body.
used to happen to me when i beat on it...... went away in like 20 min (one time i was lucky enough to have a quicky when it happened
) mine never turned off tho it just wouldn't let me rev above 1k i think it was.... maybe 2k now that i think of it lol
happends to me sometimes to and i have a 05 ss and its throwing 7 code one of them is the maf clean the tb and maf and unplugging the battery has never work for me after the car does it system check the light always comes back
So it seems like the OP has a couple different options of what the code could be. Get it scanned from autozone. Let us know.
Holy ****... 7 of them.. I have this one and it pisses me off, i couldnt imagine 7. lol
Last edited by SCcobaltSS; Feb 26, 2009 at 12:40 PM. Reason: Automerged Doublepost
You need to check for the CPS sensor
Crank Shaft Positioning sensor ill do that. If the censor goes bad the car will stall and died.
I got my replace at the dealership...
i think the code is oo35p something like it.
I had this happen and they ended up replacing everything, sensors, pcm, plugs, took them 3 weeks to figure it out, they really never figured out what caused the issue either just went away after 1500 worth of warranty work
so i got a injen cold air and all the codes went away lol **** the air box mod
Turbo Johnny
Feb 21, 2019 09:41 AM
twilson380
Sep 14, 2015 10:52 AM
