Engine disabled engine pwer reduced help!!!
Old May 19, 2012 | 04:00 PM
Shogokuma's Avatar
recently i had a control arm bushing changed on the passenger side (front) and the mechanic had to blow torch the bolt off because it was seized, (canada) is there any sensor near that place that could have melted since the sway bar bushing was completelty melted and he had to replace the bushing. or it this related to timing?
im getting really sick of my cobalt ive had nothing but problems week after week for years.
Old May 19, 2012 | 04:21 PM
nhanson's Avatar
You could scan for code(s).
Some codes trigger the engine disabled and power reduced (limp mode) and wont come out of it until they are cleared.
Old May 19, 2012 | 04:54 PM
Shogokuma's Avatar
ok i will scan tomorow when i get back from work. and post codes
Old May 19, 2012 | 09:30 PM
ef3309ct's Avatar
Yea the same thing happened to me today..changed my struts got that engine message. Cleared code and it was fine. Was a throttle code
Old May 20, 2012 | 01:03 PM
Shogokuma's Avatar
p0122 powertrain Throttle/Pedal Position Sensor/Switch "A" Circuit Low
p0140 O2 Sensor Circuit No Activity Detected
p0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High
p2135 Throttle/Pedal Position Sensor/Switch "A" / "B" Voltage Correlation
p2101 Throttle Actuator Control Motor Circuit Range/Performance
P1681
Type PowerTrain
Status Stored
ECU 10
Description Manufacturer Defined
those are the codes, recently i cleaned my throttleboddy what would i have done wrong?
Old May 20, 2012 | 01:07 PM
nhanson's Avatar
Did you plug it back in correctly?
Old May 20, 2012 | 01:10 PM
Shogokuma's Avatar
yeah it was like 2 months ago..
Old May 20, 2012 | 01:29 PM
Shogokuma's Avatar
so is this pedal or throttle body related what do you guys think?
Old May 20, 2012 | 02:00 PM
Shogokuma's Avatar
i found that the throttlebody sensor plug was unclipped. trying to push it in dosent seem to clip at all. i must have broken the clip when i pulled it out.
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
OPCrer
Sep 27, 2015 08:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
