engine power reduced light???
Old 07-15-2009, 12:55 PM
pookie025's Avatar
Unhappy engine power reduced light???
so today i was backing up in reverse and gave it a little gas and where our gas milage and tire pressure is it beeped and said engine power reduced. i drove off and had noooooo power at allllllll wtf. i turned off the car and started it back up. the signaL came up again but the car felt like it had the power from before. got home, restarted it again and no signal came on. im worried, is this limp mode, and will my car be ok.
cobalt123's Avatar
i had this awhile back it was because my engine was too hot
Old 07-15-2009, 06:34 PM
pookie025's Avatar
will it be ok
hello anybody got any advice
Old 07-15-2009, 08:29 PM
Gene Culley's Avatar
Talking
Gotta have a code to get any ideas.
Old 07-16-2009, 01:17 PM
pookie025's Avatar
this ******* **** came on again only in reverse im pissed
Old 07-16-2009, 01:48 PM
gbuttion07's Avatar
it happened to me and the idiots have had mine for 3 weeks.
Old 07-16-2009, 01:51 PM
cobalt123's Avatar
possible pcm/throttle body issues
Old 07-16-2009, 02:09 PM
pookie025's Avatar
i just got my yune so mabey it was that trifecta
Old 08-31-2009, 03:43 AM
pookie025's Avatar
i called onstar and they told me it is my fuel pressure regulator solenoide 1 has low voltage. i noticed when reduce engine power comes on my fuel pressure goes down to 72 psi. where is the fuel pressure regulator and it prolly disconnected or something. any help please
Old 08-31-2009, 03:44 AM
MoePwR's Avatar
have you used a ziptie to hold down your charge piping?
Old 08-31-2009, 03:45 AM
pookie025's Avatar
what do you mean i have aftermarket injen piping
Old 08-31-2009, 03:46 AM
MoePwR's Avatar
well when you had stock piping did you use a ziptie cause it would pop off?
Old 08-31-2009, 03:51 AM
pookie025's Avatar
dude your in the wrong area and no it never popped off lol
any ways back on topic wheres the fuel pressure regulator
Old 08-31-2009, 03:53 AM
MoePwR's Avatar
im saying i got the same code but i guess you dont want any help....so too bad. p0091 right?
Old 08-31-2009, 04:00 AM
pookie025's Avatar
its not a check engine light its in the dic area with the tire pressure and instant gas milage it come up and says REDUCE ENGINE POWER then in my rpd my fuel pressure drops to 72 psi when im supossed to be running like 600 more at normal idle. the car hass noooooo power. onstar said im not getting any fuel to my fuel rail do to low voltage on the fuel pressure regulator solenoide......... so he said there is a loose wire. i asked him if it was my check engine light and he said noo that i have a check engine light do to not haveing a cat. soooo the wire is loose. reduce engine power comes on when it wants to or when ever its reading low voltage.
x8xViperx6x's Avatar
he was just asking a simple question, easiest things cause the biggest problems.. just sayin.
Old 08-31-2009, 04:02 AM
pookie025's Avatar
i know lol i just thought he was lost lol jk its ok if i sounded like a dick sorry didnt mean it lol soooo any advice
Old 08-31-2009, 04:13 AM
Hope this helps, no personal advice, but people around these parts can be very helpful. I just searched and found a few threads, sorry if they do not help.
https://www.cobaltss.net/forums/show...+reduced+light
Old 08-31-2009, 04:20 AM
MoePwR's Avatar
i know exactly whats wrong but hes just bein a dick.... theres a wire mesh to the righ of your charge piping and theres 1 little wire that seperates and goes to your fuel reg..... check it i bet its rubbing on the metal frame....
there you go....next time dont be an ass https://www.cobaltss.net/forums/08-10-ss-turbocharged-general-discussion-152/%2Azip-tie-mod-warning%2A-167772/
Old 08-31-2009, 04:51 AM
YaKkO's Avatar
there you go....next time dont be an ass https://www.cobaltss.net/forums/showthread.php?t=167772
I'm having issues picturing where the area is your talking about bro???
Old 08-31-2009, 12:56 PM
MoePwR's Avatar
thats on the drivers side next to your engine there will be a black bracket and to the right of that will be a cluster of wire
Old 08-31-2009, 01:02 PM
YaKkO's Avatar
I'm gonna find that and preemptively strike that **** lol. Cause my CP moves alot under load I noticed so im sure its rubbin on something...
Old 09-01-2009, 01:43 AM
pookie025's Avatar
so went to my techs shop to install my hks bov and i asked him about the reduce engine power, so we went on the fourms and red this post and for sure he was right the yellow and purple wires were chafed on a black bracket and were cut open, so we protected the wires and tapped them up. i earlier i did apologize and sorry again you were right lol
Old 09-01-2009, 01:45 AM
YaKkO's Avatar
sweet man. good to hear
Old 09-01-2009, 01:52 AM
berto's Avatar
so is everything fixed??
Quick Reply: engine power reduced light???
