Engine reduced
Old 01-14-2018, 12:41 PM
mechanicalidiot's Avatar
Engine reduced
P0340
P0601
these are the codes im getting, i was told the pcim needs to be flashed or replaced due to it throwing false codes that turn the engine off.
any help is greatly need.
thank you
Old 01-14-2018, 02:41 PM
Sharkey's Avatar
p0340 is camshaft position sensor circuit.
p0601 is Internal Control Module Memory Checksum Error
the p0601 points to a pcm memory error, and the fix generally is replacing the pcm and having the new one flashed.
Old 01-15-2018, 07:38 AM
jdbaugh1's Avatar
When I thought my ECM went bad I bought a pre-flashed ready to go used ECM from https://www.flashmastersecm.com/pages/about-us. They seem to have good prices and besides the security relearn procedure they are plug and play. Also, if you have a tune obviously you would have to flash that on there as well.
gracefulbutterfly
08-27-2020 09:04 PM
2.4SlowassBalt
09-22-2011 05:12 PM
anthonyd3000
07-09-2010 08:56 PM
Viceversa10
07-04-2010 02:08 PM
Viceversa10
05-13-2010 08:44 AM
Quick Reply: Engine reduced
