fans come on too late.
Old Jan 30, 2012 | 08:48 PM
turbosmart4's Avatar
Unhappy fans come on too late.
a couple months ago my car always stayed below 200F even after pulls, but now its 200 and up at idle.. after checking everything i noticed the fans come on late, and i didnt want to make a new thread cuz ppl seem to get mad for some reason, even when its to ask for help..but i have to ask in case someone here had the same problem... i have searched on other forums and many cars have had the same problem, but EVERYONE stops posting after they seem to have found a solution....
anyways, my cooling fans use to come on at 190F something, now at 223F, and no this is not the way its suppose to be.... when cooling fans come on temp goes down to 196 or so... when AC is on the car stays at normal temp cuz fans come on. replaced relays and temp sensor, still nothing. ANY help will be appreciated!
Old Jan 30, 2012 | 09:00 PM
mkulrey13's Avatar
It IS normal. fans come on at 220ish. Its in the manual i believe. Our motors run hot anyways. there was something wrong if they were kicking on at 190 and you didnt change that in your tune.
Old Jan 30, 2012 | 09:10 PM
even for a 2006 lsj?? ive heard the NA cobalts run hot but not these... my buddy's fans come one before 200 too
Old Jan 30, 2012 | 10:28 PM
mkulrey13's Avatar
I believe 234 is the magic number where you sould start to think where are my fans.
Old Jan 30, 2012 | 10:37 PM
ben_gary's Avatar
my lsj's fan turned on around 225 when i was stock. now(tuned) set to turn on at 190
Old Jan 30, 2012 | 10:44 PM
what a relief! thank you guys! : ya'll have 180F thermostats right?
Old Jan 30, 2012 | 11:23 PM
mkulrey13's Avatar
I have stock what ever that is.
Old Jan 30, 2012 | 11:46 PM
lol thermostat. also.. is it normal for our cars to go up in temperature after you turn off the car and turn it back on after a few mins. ex. u pull up to a gas station (189F) turn off the car... after pumping gas, u get inthe car, turn it back on and the temp is 196F.. is this normal?
Old Jan 30, 2012 | 11:53 PM
nhanson's Avatar
Its probably heat soaking...so yes normal
Stock tune is 220* for fans. Get a tune and set fans to 100% at 200* (this is what i did) I never see over 200* unless im beating on it on a hot day.
Old Jan 31, 2012 | 12:08 AM
Stamina's Avatar
Yup.
If you're tuned, the fan temps can be altered too.
Just remember: Radiators are heat exchangers that work by shedding heat into the air that passes through them. If the car isn't moving, then that means no airflow. No airflow means no efficient way to get rid of the heat, and the temps will tend to rise.
Old Jan 31, 2012 | 12:16 AM
Mindrot's Avatar
Dashhawk enables you to manually turn the fans on and or keep them on
Old Jan 31, 2012 | 12:28 AM
hmm very useful information , i think i will be getting a tune sometime in the near future, thanks guys : i had never heard of dashhawk, im gonna google it lol
Old Jan 31, 2012 | 01:20 AM
Stamina's Avatar
The Dashhawk is a multifunction gauge/tool that plugs into the car.
Old Jan 31, 2012 | 11:25 PM
does dashdaq let you change fan turn on points too? (assuming you must know since you have one)
Old Jan 31, 2012 | 11:30 PM
Stamina's Avatar
No idea. I don't have one. I just know general info about them since it's one of only a handful of popular scan guages (Dashdaq, Dashhawk, PLX, and Interceptor), and a customer of mine in another town has one that I've briefly been able to see and play with. I have a Dashdaq, which is completely different.
That being said, I could be wrong, but I do not believe that you can change the fan points, as that is something programmed into the ECU that typically requires reflashing with a more sophisticated tuning device.
Old Jan 31, 2012 | 11:40 PM
this is what ive found, i want something like this, but this product is for trucks
Hypertech - Adjust Cooling Fan On/Off Temperatures
With the Hypertech Power Programmer, you can electronically adjust the “on/off” temperatures of your vehicle’s electric cooling fans. When used with a Hypertech PowerStat, low-temperature thermostat, this produces a cooler, denser intake charge that allows the engine to make more power. A cooler engine is also less likely to detonate under heavy loads. That means better performance for you and longer life for your engine.
Old Feb 1, 2012 | 01:03 AM
nhanson's Avatar
You don't want those types of tuners/programmers. Get a custom tune
Old Feb 1, 2012 | 09:22 PM
how much is it for a tune? im a noob man
Old Feb 1, 2012 | 09:44 PM
nhanson's Avatar
Find someone with HP tuners in your area.
Price depends on tuner. HP tuners credits will run you $100 plus whatever the tuner charges.
Old Feb 1, 2012 | 09:46 PM
ive been looking, but ive only found trifecta
Old Feb 1, 2012 | 10:43 PM
nhanson's Avatar
any shops around you?
Old Feb 1, 2012 | 10:46 PM
all the way to houston i think... i dont trust local though... most of them went w me to school :S
Old Feb 1, 2012 | 11:08 PM
kikal8's Avatar
i have found that changing the fans to heat, and having them blow out the feet turns the fans on for some reason ha. usually when im sitting for awhile ill turn the heat to my feet and put the speed to 1 and idle temp stays around 189
Old Feb 1, 2012 | 11:15 PM
i do that too but starts getting really hot in the cabin and with a kid in the back its not a good idea lol mine reads from 189 to 196 when i turn it on.. if i dont it will rise all the way to 223 and my low speed fans come on
Old Feb 1, 2012 | 11:33 PM
nhanson's Avatar
Feet only setting, Defrost and feet, and defrost all turn on the A/C compressor (which turns the fans on to move air through the condenser). I believe 40 or 45* is when the compressor doesnt turn on due to cold temp.
