Firing order?
Old Jul 6, 2008 | 01:13 PM
SSdan's Avatar
Firing order?
Does anyone know the firing order of the LSJ from left to right?
Just ran compression and from left to right the numbers are 150,180,180,180.
Now obviously I know there is a problem with the low cylinder reading, just need to find out what piston it is.
Old Jul 6, 2008 | 01:14 PM
D4u2s0t's Avatar
1 3 4 2
Old Jul 6, 2008 | 01:19 PM
SSdan's Avatar
Must be a cracked ring land on #1.
Car still makes awesome power and pulls hard.
Old Jul 6, 2008 | 01:23 PM
lsjwannabe's Avatar
nitrous??
Old Jul 6, 2008 | 01:44 PM
SSdan's Avatar
Everything is in. Solenoids aren't wired yet nor is the bottle filled so I never got to spray it.
I've had the suspicion for a while now, just never got to test it until today.
I just ran into trix's new block thread and everyone is saying his pistons that went are 1 and 4, both on the end which contradicts what the firing order listed above is.
Old Jul 6, 2008 | 01:45 PM
Witt's Avatar
I think you are confusing firing order with cylinder designation.
Firing order is as stated above: 1 3 4 2
Cylinder designation is 1 at the front of the engine (at the timing chain) and 4 at the rear of the engine.
Old Jul 6, 2008 | 01:48 PM
SSdan's Avatar
Thank you
Old Sep 2, 2010 | 09:52 AM
Kaiser's Avatar
so if im following this properly - cylinder one is the one far left when your looking in the hood... I'm trying to figure out what wrong with my injector on cylinder 2. im getting a jerky feeling under power, but its not all the time, when it does it my check engine light comes on. after that it will go off....
Old Nov 23, 2014 | 06:20 PM
Cody Crull's Avatar
Unhappy
Hey Kaiser I know it's four, almost five years later but did you ever find out what it was? I'm having the same problem.
Old Nov 23, 2014 | 06:53 PM
mrbelvedere's Avatar
busted piston ringland
Slick_Nick
Sep 28, 2015 09:15 PM
ashalle2
Sep 27, 2015 03:28 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
DisJuan
Sep 7, 2015 04:24 PM
