Fix Traction Control Button! HELP
alright, so i just got off work and decided i wanted to remove my dash trim. as i was removing the piece to the right of the steering wheel, (where the TC button is located) i guess i pulled too hard and the wire got disconnected from the harness. does anyone know how to connect this wire back?? i just can't exactly tell how it's supposed to connect... and i'm pretty dumb when it comes to wires and stuff... maybe someone who is familar with removing the dash trim? thanks!
damn dood you cant NLS and use competitive mode now. BOOOO guess u gotta have fun the old fasion way. lolll you should be able to slide it back in or sodder the connections back together. find an asian guy imo
Looks like you’re already on your way towards fixing your wiring. If there’s anything I can help with (look into warranty/recall information on your vehicle), don’t hesitate to get in touch!
Sarah
GM Customer Service
Sarah
GM Customer Service
You actually managed to pull the switch itself apart
You might be able to glom it back together but I would be looking for a new one.
Even from the dealership I can't see it being all that much.
But I bet if you gave him a t183 calc an some speaker wire, he'd tune the **** outta yet mustang!
